 Post subject: SandDisk Ultra II 480 GB SSD files can't be seen
PostPosted: September 5th, 2018, 5:17
I was running Windows 10 on this drive and on the last bootup it had the black screen with the white circle.
It wouldn't boot into windows and I tried to recreate the Windows boot files to no avail.
I searched and followed the instructions on this page: https://triplescomputers.com/blog/casestudies/repair-a-corrupted-efiuefi-boot-sector-and-bcd/
Afterwards I saw all my files had gone on this drive. I used EaseUS Data Recovery Wizard and Stellar Phoenix Windows Data Recovery to scan for files and they found nothing.
How can I recover my files?
 Post subject: Re: SandDisk Ultra II 480 GB SSD files can't be seen
PostPosted: September 17th, 2018, 6:06
exit diskpart, and then perform a chkdsk command
DISKPART> format quick fs=fat32
Probably you lost data as a result of CHKDSK, Format or both. Data should still be recoverable, but depending on how much work CHKDSK did and any other actions you made, it may not be a perfect recovery. If software already found nothing, maybe it is time to get it looked at by a professional who will know best approach and software to use - if data is important that is.
