Post new topic Reply to topic  [ 35 posts ]  Go to page Previous  1, 2
 Post subject: Re: Apple Customer Data Migration Tool - can't get it to wor
PostPosted: October 21st, 2018, 3:08
I notice that one Touchbar model has two JHL6540 Thunderbolt 3 Controllers. Each appears to be paired with its own CD3215C00 chip. There is a connector adjacent to each chip.
MacBook Pro 13" Touch Bar 2017 Teardown:
https://ko.ifixit.com/GuidePDF/link/92171
The following Mac has a single CD3215C00 chip and connector, but no Thunderbolt controller.
Retina MacBook 2017 Teardown:
https://ko.ifixit.com/GuidePDF/link/92172
Both models have an integrated PCIe-based SSD.
ISTM that the CD3215C00 / CD3215B03 chips could be 4-lane PCIe receivers/transmitters.
Here are two examples of standard parts:
Quad Channel (Half x4 Lane) PCIe Redriver/Equalizer:
http://www.ti.com/lit/ds/symlink/sn65lvpe504.pdf
Dual Channel x1 PCIe Redriver/Equalizer:
http://www.ti.com/lit/ds/symlink/sn65lvpe501.pdf
Therefore ISTM that the USB-C cable need not be an "active" type since there is a redriver chip at each end.
PostPosted: October 21st, 2018, 18:44
Teardown of the MacBook Pro 13-inch Late 2016, with four Thunderbolt 3 ports and Touch Bar (model number - A1706):
https://ko.ifixit.com/GuidePDF/link/73480 (PDF)
https://www.ifixit.com/Teardown/MacBook+Pro+13-Inch+Touch+Bar+Teardown/73480
PostPosted: October 21st, 2018, 19:35
USB 3.1 cables have a differential impedance of 90 ohms whereas PCIe cables are 100 ohms. This can be seen in TI's datasheets for its redriver ICs.
Dual Channel USB3.0 Redriver/Equalizer:
http://www.ti.com/lit/ds/symlink/sn65lvpe502.pdf
Therefore ISTM that Apple's migration tool would normally require a 100 ohm cable for an end-to-end PCIe link, unless the CD3215C00 / CD3215B03 chips were performing impedance conversion/matching from 100 ohms to 90 ohms, and vice versa???
PostPosted: October 23rd, 2018, 15:46
After reading the following articles, I believe that the circuit layout is as in my block diagram.
Understanding I/O on the mid-2017 iMac:
https://glennklockwood.blogspot.com/2017/08/understanding-io-on-mid-2017-imac.html
Thunderbolt Technology Overview (using Intel 82524EF):
https://developer.apple.com/library/archive/documentation/HardwareDrivers/Conceptual/ThunderboltDevGuide/Basics/Basics.html
| Dead Mac mainboard  |
|     | PCIe  |       |
|     | SSD   |       |
|         | migration |
|      .--'--. conn   |
          |   PCIe flat
          |  cable (100 ohm)
|end- |JHL6540|  | PCIe  |   |
|point|T/Bolt |--| clock |   |
|mode | cont  |  | gen   |   |
|         |      9FGV0441    |
|    |CD3215B03| |         | |
|    | USB3.1  | |TPS51980A| |
|    | redriver| |  PMIC   | |
       '--.--'  USB-C conn
          | USB-C cable (90 ohm)
       '--.--'  USB-C conn
|    |CD3215C00|   |
|    | USB3.1  |   | Destination
|    | redriver|   |  Mac
|host |JHL6540|    |
|mode |T/Bolt |    |
|     | cont  |    |
|         V        |
|    PCH PCIe Bus  |
PostPosted: October 23rd, 2018, 21:52
https://en.wikipedia.org/wiki/Thunderbolt_(interface)
When a system with Thunderbolt boots, it will load and execute Option ROMs from attached devices.
Does this mean that the target Mac must be booted after the migration tool has powered up?
|   .-------.       |  Dead Mac
|   | PCIe  |       |  mainboard
|   | SSD   |       |
|       | migration |
|    .--'--. conn   |
       |:| PCIe flat cable (100 ohm)
|      | |  ___| Option |    |
|      | | |   |  ROM ? |    |
|   |JHL6540|  | 9FGV0441 |  |
|   |T/Bolt |--|  PCIe    |  |  Apple
|   | cont  |  | clock gen|  |  Data
|   '---.---'. '-----.----'  |  Migration
|       |     \      |       |  Tool
|  |CD3215B03| |           | |  Thunderbolt
|  | USB3.1  |-| TPS51980A | |  controller
|  | redriver| |  PMIC     | |  in end-point
|  '----.----' '-----------' |  mode
     .--'--.  USB-C conn
     '--.--'  USB-C conn
|  |CD3215C00|   |
|  | redriver|   |  Mac
|   |JHL6540|    |  Thunderbolt
|   | T/Bolt|    |  controller
|   |  cont |    |  in host
|   '---.---'    |  mode
|       V        |
|  PCH PCIe Bus  |
PostPosted: December 7th, 2018, 20:51
Planning on purchasing on the Apple Data Migration Tool. What has been your experience in terms of success in using the tool ? Prices on Ebay seems very reasonable.
PostPosted: December 8th, 2018, 20:25
You can buy the official tool that Apple Service Providers use. You just need to look hard for it.
PostPosted: January 14th, 2019, 13:56
So, I've bought the tool and it's on the way... I think parts of the original question remains: Will the tool work without pulling the board from the laptop? And if so, did you have to unplug the battery connection?
Soooo not looking forward to disassembling everything if I don't have to. In part because I think that the issue is that the memory is simply too full and the laptop may actually boot properly again if I can erase enough files...
thanks in advance for any help you can offer!
PostPosted: January 23rd, 2019, 8:41
I got this to work. I was doing everything right, just wasn't plugging it into the correctly specced host Mac. You need to connect it to a Thunderbolt 3 port.
Connecting it to a USB C port does not work.
The Apple Thuderbolt to USB C adapter does not work.
You do not need to take the mainboard out of the Mac.
You do not need to disconnect the battery from the Mac.
You just remove the back cover, use a T3 to remove the screws that cover the connecting port, connect the tool, and then connect the tool to your host Mac via Thunderbolt 3. The disk then appears on the host Mac like it would any other disk. I've done one successfully today, about to try the next one. The way I had it connected early on in my post was correct.
Data Recovery Cape Town
PostPosted: January 23rd, 2019, 10:06
It just connects up like this: https://www.southbit.co.za/apple-macboo ... -recovery/
PostPosted: January 23rd, 2019, 15:27
Thanks for the update Nick!
PostPosted: January 24th, 2019, 4:51
Nice!
About to work with a similar case, so this comes very handy!
WD Trusted Partners
PostPosted: January 24th, 2019, 8:21
I did one yesterday and two today, all 3 of them worked. Seems the onboard storage is quite resilient as all 3 machines had severe liquid damage. I was pleasantly surprised.
PostPosted: January 25th, 2019, 5:14
I did tell you that about 3 months ago :wink:
It works well. I believe removing the original plug cap isolates the entire SSD and power source from the rest of the mainboard completely which is great.
PostPosted: January 25th, 2019, 5:16
You did, thank you :) I just couldn't get access to a Mac with Thunderbolt 3 until now.
Users browsing this forum: Google [Bot] and 3 guests
