 Post subject: Where to buy USB 3.0 type A male connector with two layers?
PostPosted: January 16th, 2019, 13:35
Most of the USB 3.0 flash drives that I see have a connector where the rear pins are spread over two layers, like the one of the left of the attached picture.
On the Internet, I could only find the model pictured on the right of the picture, where the pins are all at the same level.
Unfortunately, this model of the USB 3.0 type A male connector doesn't have the same pitch and the pins are not aligned with the tracks of the key.
Although one can use tiny wires, I would prefer finding the connector model of the key.
I'm looking for quality connectors and not ones with a poor alloy.
Can you recommend any source?
