HDD GURU FORUMS http://forum.hddguru.com/ |
ATJ3315 CONTROLLER PLAYER http://forum.hddguru.com/viewtopic.php?f=10&t=37987 |
Page 1 of 1 |
Author: | data-medics [ January 24th, 2019, 16:14 ] |
Post subject: | Re: ATJ3315 CONTROLLER PLAYER |
I think you're massively oversimplifying the difficulty of getting the data off that. |
Author: | fzabkar [ January 24th, 2019, 16:25 ] |
http://pdf-file.ic37.com/uploadpdf_old/SAMSUNG/K9GBG08U0A_datasheet_898290/146569/K9GBG08U0A_datasheet.pdf |
Author: | arvika [ January 24th, 2019, 18:24 ] |
We solved few same cases last weeks. It not easy job. ECC works after applying XOR, after it you must assembly the image in correct way. |
Author: | bayerecep [ January 27th, 2019, 9:57 ] |
arvika wrote: We solved few same cases last weeks. It not easy job. ECC works after applying XOR, after it you must assembly the image in correct way. I figured it out and got all the data. But my intention is to read directly via Mp3 without removing the chip |
Page 1 of 1 | All times are UTC - 5 hours [ DST ] |
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group http://www.phpbb.com/ |
