 Post subject: Problem reading Samsung EVO+ MicroSD
PostPosted: February 10th, 2019, 13:47
I'm trying to read Samsung EVO+ microsd, I've used Ignore busy cause I didn't find the R/B.
the dump turned out to be bad i've attached a bitmap screenshot.
What is the problem here? Does anyone else have this problem?
Thanks.
 Post subject: Re: Problem reading Samsung EVO+ MicroSD
PostPosted: February 10th, 2019, 17:11
What ID do you have? Did you ask support for help?
Odzyskiwanie danych
PostPosted: February 10th, 2019, 23:16
most flash don't have any relevant data from 0x0 to after the first block. can have some firmware there or something but go forward in the dump a bit.
You are right though, the dump doesn't look right
PostPosted: February 11th, 2019, 5:54
ID - ECDE88BF, I didn't ask support for help because I've heard there is a problem with Samsung EVO+ SD cards so I thought this is the problem, is it not?
HaQue the screenshot is not from the beginning.
PostPosted: February 15th, 2019, 6:18
I believe we can help you with case. Drop me PM or send mail to: patryk @ rusolut.com
VISUAL NAND RECONSTRUCTOR. A big revolution in chip-off data recovery
