 Post subject: ADATA S510 Firmware Fail
PostPosted: May 4th, 2019, 16:39
I have an ADATA 60GB SSD here. Here the firmware update with the official software of ADATA failed. Is there a way via Termial to reload the firmware?
 Post subject: Re: ADATA S510 Firmware Fail
PostPosted: May 4th, 2019, 16:59
If you don't need the data …
http://forum.ru-board.com/topic.cgi?forum=84&topic=5360
PostPosted: May 5th, 2019, 7:18
My Russian is unfortunately too bad to read it :wink:
The Data on The SSD is not needed.
PostPosted: May 5th, 2019, 17:23
Use Google's translator:
https://translate.google.com/translate?hl=&sl=ru&tl=de&u=http%3A%2F%2Fforum.ru-board.com%2Ftopic.cgi%3Fforum%3D84%26topic%3D5360
Restoring SSDs on a SandForce SF-2XXX controller (Video instruction):
https://www.youtube.com/watch?v=vSCr3UzyzhM
PostPosted: May 8th, 2019, 15:15
thx for you help.
I looked at the list and have 2 possible configurations. but which is the right one?
PostPosted: May 8th, 2019, 16:34
You can choose either. The lower user capacity will have correspondingly more overprovisioned space, resulting in higher performance.
https://www.seagate.com/au/en/tech-insights/ssd-over-provisioning-benefits-master-ti/
PostPosted: May 8th, 2019, 19:12
I can Say That... The SSD is alive again! :D
Thanks alot :-)
PostPosted: May 10th, 2019, 17:41
Does anyone know if this SSD has a temperature sensor? I could not locate any on the board.
PostPosted: May 10th, 2019, 18:24
I don't recognise any discrete temperature sensor IC.
What is the marking on U73? Is it "F2C"?
Is there a temperature attribute in the SMART report?
PostPosted: May 10th, 2019, 19:30
The Marking is 14BBJ.
Smart say Temp. not Supportet and SSD Toolbox say Temp over 60000 Grad
PostPosted: May 10th, 2019, 19:44
That's U72.
MP6400DJ-01, adjustable Programmable-Delay Supervisory Circuit, marking 4Bxx, TSOT23-6:
http://www.mouser.com/ds/2/277/MP6400_r1.1-371744.pdf
PostPosted: May 13th, 2019, 16:06
I think this ssd has no temperature sensor.
