 Post subject: MicroSD READ-ONLY behaviour in Android
PostPosted: September 11th, 2019, 5:15
Hello guys,,,
I was wondering if someone knows about this issue or had similar cases like this...
MicroSD memory added to Android Mobile (Android 6+ & higher) and you use it for a while (Enabled Encryption or not its the same)
when you pull it out and connect to windows you are able to READ its data but you CANNOT FORMAT/MODIFY it
no matter what you do, it says Format done, but nothing changes... DATA remains the same (either Encrypted or not)
anyone got similar to this scenario?
Note: I came up with a result about this matter and wanted to verify with those who had similar cases...
you may PM if don`t want to go public about it...
thank you
:wink:
 Post subject: Re: MicroSD READ-ONLY behaviour in Android
PostPosted: September 11th, 2019, 6:27
Is it a Kingston branded memory? or does this happen with different flash cards?
PostPosted: September 11th, 2019, 7:25
Any brand,,,
I have more than 10 now for research, Sandisk, Kingston and some other unbranded too
PostPosted: September 11th, 2019, 8:19
is it the read only attribute on the actual partition? or were they exFAT and not really FAT32?
this page https://forum.fairphone.com/t/sd-card-suddenly-switches-to-read-only-file-system/37570/6 is saying:
I figured out that instead of rebooting one can unmount the SD card (Settings -> Storage -> Chose SD Card -> Eject -> Confirm) and then mount the card again, without removing it from the device.
with a reply
Thanks for the hint. Unmounting and re-mounting the SD card does indeed work. And is faster than a reboot.
more info
https://forum.fairphone.com/t/list-of-compatible-microsd-sdxc-cards-for-fp2/33672
PostPosted: September 11th, 2019, 9:04
@ HaQue
PM Sent.
