 Post subject: USB 3.0 Connector Pinout
PostPosted: September 19th, 2019, 18:09
I got this drive from another DR company and it has no USB 3.0/3.1 header, does anyone know which pads are for USB 2.0 D+ and D-
Recover My Flash Drive
 Post subject: Re: USB 3.0 Connector Pinout
PostPosted: September 19th, 2019, 18:45
Is this a trick question? :?
https://pinouts.ru/Slots/USB_pinout.shtml
This layout would seem the most logical:
PostPosted: September 19th, 2019, 19:46
That was my first guess but it doesn't appear to work
PostPosted: September 19th, 2019, 20:16
so drive not working probably.
what are the 5 rectangular traces in the middle? some sort of signal interference mitigation or something?
looks like you may need to find a donor and use the 30 pads up top to find nand pinout. whats the drive?
PostPosted: September 19th, 2019, 20:29
I think something is fubar w/ the controller, the 3.3v rail isn't outputting the proper voltage.. I'll check the passive components tomorrow...
PostPosted: September 20th, 2019, 3:37
I think your pinout is right. Pad with 5V is cut out from two vias on the bottom from it. I guess it is the reason why you can't power up device.
PostPosted: September 20th, 2019, 15:47
So it was a trick question. :-)
PostPosted: September 21st, 2019, 9:32
it is either cut, or there is still some black coating left on there where laser missed.
Users browsing this forum: Google Adsense [Bot] and 11 guests
