Since traveling yesterday my computer has been acting up. Anything that requires loading something from the SSD takes between 5-10 seconds, sometimes zero.
I did some digging and found out that my hard drive is only active in intervals. Below is an example of when I tested my drive:
It took a very long time to finish this test even though it's an NVME drive.
Is there any quick solution to this? Could it be that it is not sitting well in the slot anymore or that it is simply damaged?
Thank you for any help
