Amarbir[CDR-Labs] wrote:
Well,
What Is The IC Number According To You ,Is That Supported ,I Think Its a Old Type Serial EPROM like the 93 series .
As I said it's an I2C EEPROM, it uses AT24Cxx Algorithm, it has nothing to do with microwire 93cxx series.
It's supported by both programmers as 24c256, i can read / write and it works fine.
The problem might not be at all in this eprom, maybe it's not even used. A conclusion can be made only if compared with a working one of the same model.
I have a viewpoint on some of the services that we guys cannot handle ,Lets take a typical Example of foreign DR Firms
1 : Logical Recovery 150 ~ 250 Dollars US
2 : Semi Physical 450 Dollars US
3 : Physical 800 Dollars US
So some of our seniors can do this but they quote so high prices ,Whats the point ,When the secret remains with them ,They should quote sensible so that they make very good money and get repeat job as all clients will approve .Example when i wanted a quote for Dual translator recovery i got a quote that none in india approve ,I tried to give rates to two clients
Well they put their time effort and knowledge to develop these solutions and it's up them how high they appreciate their work.
Also it's up to the market to decide if the price will be paid or declined.
Maybe they have enough cases to work on which makes it worth keeping the secret.
But hey, never know until you are in their shows.
