 Post subject: USB Key 32GB - Drive not detected at all, little LED is on
PostPosted: April 16th, 2020, 14:54
Hi guys,
I got that USB Key 32 GB. The drive is not detected at all however the little led does turn on red, steady, not flashing. I am looking for the oscillator but it must be SMD and I am not sure which one. I tried searching using the info on PCB but can't find anything relevant.
Sam
 Post subject: Re: USB Key 32GB - Drive not detected at all, little LED is
PostPosted: April 16th, 2020, 17:06
That controller is probably using an internal oscillator.
I would check in the device manager, if it comes up in the disk drives section as the controller name with 0 capacity.
If it does, the problem is probably in the NAND.
No bitcoin donations :)
PostPosted: April 17th, 2020, 2:49
It's odd as there's nothing on W10 Disk Management or MacOS disk Utility however the light is on. It looks like controller doesn't talk to PC ?
PostPosted: April 17th, 2020, 5:17
It would take at least an oscilloscope to check if it really talks over the usb (or a proto analyzer) and the NAND.
There's not much you can do without tools, apart from checking broken soldering...
PostPosted: April 17th, 2020, 6:06
Yeah, I'll get an oscilloscope today.
PostPosted: April 18th, 2020, 8:09
I've made some progress. I've connected 5V to controller U1, now USBkey is recognized by PC. I can't yet access data, USB is listed but not can't initialize it, doesn't report capacity. I am sharing if that can help someone.
PostPosted: April 18th, 2020, 8:27
Looks like the problem is the "write-protect" now.
PostPosted: April 18th, 2020, 8:29
i guess it is time for a chip-off. Can you handle it?
