88325VA110 chip
http://forum.hddguru.com/viewtopic.php?f=10&t=44167
Author:  arvika [ March 13th, 2024, 10:00 ]
Post subject:  88325VA110 chip
question probably to fzabkar ;)
Can anybody recognize the chip from photo below? Marking: 88325VA110. Is it possible buy it? I can take from donor, but need more quantity.
Author:  fzabkar [ March 13th, 2024, 12:23 ]
Post subject:  Re: 88325VA110 chip
https://www.qorvo.com/products/p/ACT88325#documents
"110" is the default configuration which defines the initial supply voltages and power sequence.
https://www.hddoracle.com/viewtopic.php?p=24271#p24271
"CMI 110 is optimized for a custom SSD controller."
Unfortunately, the "110" configuration is not listed at Mouser:
https://au.mouser.com/c/?q=ACT88325
Author:  einstein9 [ March 14th, 2024, 3:45 ]
WD Blue SA510 1TB ( I went through this before couldn't`t find)
Author:  arvika [ March 14th, 2024, 18:15 ]
fzabkar, thank you very much for this usefull info.
einstein9, yes, donor is not a problem. It could be less size.
Author:  fzabkar [ March 14th, 2024, 19:43 ]
@arvika, it might be worth looking at the available CMI voltage profiles. If you choose one that has a similar (and safe) profile, it could be that the controller will reconfigure the voltages via I2C after power-on.
You could test this idea by shorting the crystal (to disable the controller) and then measure the power-up voltages. Compare these against the normal voltages. If they differ, then you will know that the controller is indeed reconfiguring them.
Author:  arvika [ March 22nd, 2024, 10:11 ]
fzabkar, thank you very much.
