 Post subject: Cannot recover Translation ST9500325AS ?
PostPosted: December 20th, 2016, 7:05
I have ST9500325AS, all heads goods (can read using utilities ) and when i try to recover translation stay forever ????
HDD family detecting...
Family ID: 3C
Selected family......................... : 3C, Wyatt
Model by ID............................. : ST9500325AS
Loading default settings!
Use the options dialog to review and save utility settings.
Then press OK!
Family default settings loading!
Tech Key...
Requesting FW Pkg ver ........ WY05D7.SDM1.DA99L2.0002SDM1
Detecting Phys Sct Size...
Result.................................. : 512
Detecting Max Head number...
Phys. heads............................. : 4
Obtaining Saved Mode Pages File information...
Reading Saved Mode Pages...
Parsing Saved Mode Pages...
SMP Dbl: 0x3C000317 - 0x037FF7FF (0x0000000F)
LBA alignment........................... : 0
Obtaining Registry File information...
Reading Registry File...
Parsing Registry File...
Media Cache
MC is not supported / NVC caching
Collecting Sys Files information...
ID Len
0 2 Reserved Defect Table (SA defect table)
1 2 Drive Information File (DIF)
2 16 Performance Parameter File (PPF)
3 1870 Primary Defect File (P-List))
4 9 Servo Adaptive Parameter File (SAP)
5 4 Manufacturing Information File (MIF)
6 85 Read Adaptive Parameters File (RAP)
7 1 Controller Adaptive Parameters File (CAP)
8 2400
9 1 SMART Configuration File
A 2251 SMART Data File
B 1000
C 64000 Serial Port Test Results File (Self Scan Log)
D 160
E 432 Data Integrity Check (DIC), HEAD 0
F 223 DIC Dummy File
13 8 Disc Registry File (settings, security, etc)
15 100 BGMS File (Directed Offline Scan)
16 2
17 40
19 24 Log File
1A 33 Log File
1B 1 Log File
1C 9
1D 128 Physical Overlay File 0
1E 128 Physical Overlay File 1
1F 640 Physical Overlay File 2
22 80 Drive Self Test (DST), Head 0
23 80 Drive Self Test (DST), Head 1
24 80 Drive Self Test (DST), Head 2
25 80 Drive Self Test (DST), Head 3
2A 9 Saved Mode Pages (HDD settings)
2B 535 R/W Operating Parameters (translator, etc)
2C 432 Data Integrity Check (DIC), HEAD 1
2D 432 Data Integrity Check (DIC), HEAD 2
2E 432 Data Integrity Check (DIC), HEAD 3
33 4576
34 640 Packed CONGEN XML definition
35 26 SMART Data
Collecting Sys File Infos completed
Collecting DT Infos...
ROM:
ID MemOffs Len
0 6020100 43520 Read Adaptive Parameters File (RAP)
1 6020000 256 Controller Adaptive Parameters File (CAP)
4 4000000 4096 Servo Adaptive Parameter File (SAP)
5 6C000 81920 Servo Firmware Table
A 60A22AC 1024 Seek Profile
13 60AD308 768 Dependent Zone Table for User Area
14 60AD608 64 Dependent Zone Table for System Area
15 0 524288 Flash ROM
1B 60AC0F0 4632 Dependent Zone Group Tables for User Area
1C 60ABFB0 320 Dependent Zone Group Tables for System Area
1D 6020120 208 VBAR Configuration File
1E 6020380 3216 Zone Format Parameters File
RAM:
ID MemOffs Len
2 60201F0 400 Zone Table
6 227840 40996 Servo Flaw Table
16 6020100 32 Drive Configuration Table
17 6022A60 1616 Temperature Control Configuration
1F 6144678 1728 RW working user preamp table
20 6144D38 72 RW working system preamp table
Collecting DT Infos completed
Reading autotuning buffer............... Ok
Searching module table in RAM... ....... Ok
Searching volume 3 file table in RAM.... Ok
Searching volume 0 file table in RAM.... Ok
Searching SMP RAM FID in RAM............ Ok
Searching Non Resident G-List FID in RAM Ok
Searching CFW OVL FID in RAM............ Ok
Searching DT table(RAM, WR) in RAM...... Ok
Searching DT table(RAM, RD) in RAM...... Ok
System Files I/O method detection... ATA(indirect)
Test : Recover translator
First start
Translation "forks" list file........... : C:\Program Files (x86)\ACE Lab\PC-3000\Bin\!Profiles\SgF3\Wyatt\ST9500325AS-0002SDM1-5VE8RX4E\Defects\TranslationForks.lba
Maximal defect chain length............. : 64
Take into account P-List................ : Yes
At ambiguity hide "left" UNC............ : Yes
Process "32 byte tail" bug.............. : Yes
Execute Reset after defect hiding....... : Yes
HDD resources backup
Folder: C:\Program Files (x86)\ACE Lab\PC-3000\Bin\!Profiles\SgF3\Wyatt\ST9500325AS-0002SDM1-5VE8RX4E\Data\SABackup\
Backup of service information completed
Switching Autoreassign OFF...
Writing Saved Mode Pages...
HDD power supply switching OFF/ON...
G-List erase...
Translator regeneration...
Result.................................. : Ok
HDD ID reading...
Detecting defects hiding cmd type...
G-List erase...
Start scanning...
"Fork" searching: 0 - 976773167
Verify sectors ext error Device error detected "UNC"
PRd: Err Rd Ph Sect 131:2:0(1)! Tech state 0x72, 0x03160080
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 131:2:0(1)! Tech state 0x72, 0x03160080
LBA : 2122782
"Fork" searching: 2122783 - 976773167
PRd: Err Rd Ph Sect 131:2:1(1)! Tech state 0x72, 0x03160080
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 131:2:1(1)! Tech state 0x72, 0x03160080
LBA : 2122783
"Fork" searching: 2122784 - 976773167
PRd: Err Rd Ph Sect 131:2:2(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 131:2:2(1)! Tech state 0x72, 0x03110081
LBA : 2122784
"Fork" searching: 2122785 - 976773167
PRd: Err Rd Ph Sect 131:2:3(1)! Tech state 0x72, 0x03160080
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 131:2:3(1)! Tech state 0x72, 0x03160080
LBA : 2122785
"Fork" searching: 2122786 - 976773167
PRd: Err Rd Ph Sect 131:2:4(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 131:2:4(1)! Tech state 0x72, 0x03110081
LBA : 2122786
"Fork" searching: 2122787 - 976773167
PRd: Err Rd Ph Sect 131:2:5(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 131:2:5(1)! Tech state 0x72, 0x03110081
LBA : 2122787
"Fork" searching: 2122788 - 976773167
PRd: Err Rd Ph Sect 131:2:6(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 131:2:6(1)! Tech state 0x72, 0x03110081
LBA : 2122788
"Fork" searching: 2122789 - 976773167
PRd: Err Rd Ph Sect 131:2:7(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 131:2:7(1)! Tech state 0x72, 0x03110081
LBA : 2122789
"Fork" searching: 2122790 - 976773167
PRd: Err Rd Ph Sect 131:2:9(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 131:2:9(1)! Tech state 0x72, 0x03110081
LBA : 2122791
"Fork" searching: 2122792 - 976773167
PRd: Err Rd Ph Sect 131:2:A(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 131:2:A(1)! Tech state 0x72, 0x03110081
LBA : 2122792
"Fork" searching: 2122793 - 976773167
PRd: Err Rd Ph Sect 131:2:B(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 131:2:B(1)! Tech state 0x72, 0x03110081
LBA : 2122793
"Fork" searching: 2122794 - 976773167
PRd: Err Rd Ph Sect 131:2:C(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 131:2:C(1)! Tech state 0x72, 0x03110081
LBA : 2122794
"Fork" searching: 2122795 - 976773167
PRd: Err Rd Ph Sect 131:2:D(1)! Tech state 0x72, 0x03160080
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 131:2:D(1)! Tech state 0x72, 0x03160080
LBA : 2122795
"Fork" searching: 2122796 - 976773167
PRd: Err Rd Ph Sect 131:2:E(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 131:2:E(1)! Tech state 0x72, 0x03110081
LBA : 2122796
"Fork" searching: 2122797 - 976773167
PRd: Err Rd Ph Sect 131:2:F(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 131:2:F(1)! Tech state 0x72, 0x03110081
LBA : 2122797
"Fork" searching: 2122798 - 976773167
PRd: Err Rd Ph Sect 131:2:10(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 131:2:10(1)! Tech state 0x72, 0x03110081
LBA : 2122798
"Fork" searching: 2122799 - 976773167
PRd: Err Rd Ph Sect 131:2:11(1)! Tech state 0x72, 0x03160080
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 131:2:11(1)! Tech state 0x72, 0x03160080
LBA : 2122799
"Fork" searching: 2122800 - 976773167
PRd: Err Rd Ph Sect 131:2:12(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 131:2:12(1)! Tech state 0x72, 0x03110081
LBA : 2122800
"Fork" searching: 2122801 - 976773167
PRd: Err Rd Ph Sect 131:2:17(1)! Tech state 0x72, 0x03160080
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 131:2:17(1)! Tech state 0x72, 0x03160080
LBA : 2122805
"Fork" searching: 2122806 - 976773167
PRd: Err Rd Ph Sect 131:2:18(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 131:2:18(1)! Tech state 0x72, 0x03110081
LBA : 2122806
"Fork" searching: 2122807 - 976773167
PRd: Err Rd Ph Sect 131:2:19(1)! Tech state 0x72, 0x03160080
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 131:2:19(1)! Tech state 0x72, 0x03160080
LBA : 2122807
"Fork" searching: 2122808 - 976773167
PRd: Err Rd Ph Sect 131:2:1A(1)! Tech state 0x72, 0x03160080
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 131:2:1A(1)! Tech state 0x72, 0x03160080
LBA : 2122808
"Fork" searching: 2122809 - 976773167
PRd: Terminated by user : Error requesting command state "Rd Ph Sect" (Drive is not ready)
Key:Terminated by user
Surface scanning error (UNC) : PRd: Terminated by user : Error requesting command state "Rd Ph Sect" (Drive is not ready)
LBA : 2122809
"Fork" searching: 2122810 - 976773167
Verify sectors ext error Operation aborted
LBA : 2122810
 Post subject: Re: Cannot recover Translation ST9500325AS ?
PostPosted: December 20th, 2016, 7:06
can we see head resistance and V40 output ?
Data Recovery Pakistan
PostPosted: December 20th, 2016, 10:57
V4
Reassigned Sectors List
Original New log log log phy phy
LBA PBA cyl hd sctr zn cyl hd sctr SFI
Alt Pending Total Alted Total
Entries Entries Entries Alts Alts
Head 0 0
Head 1 0
Head 2 0
Head 3 0
Total 0 0 0 0 0
Total Alt Removals: 0
Checksum = 0000
F3 T>V40
Nonresident GList 0 entries returned
Total entries available: 0
PBA Len Flags Phy Cyl Hd PhySctr SFI
F3 T>V10
P List
log log phy length
head cyl cyl in symb SFI flags
1 1B9 1B9 3FD B081E 80 scr fill
1 1BA 1BA 3FD B081E 80 scr fill
1 1BB 1BB 3FD B081E 80 scr fill
0 2B6 2B6 400 72B4D 80 scr fill
0 2B7 2B7 400 72B4D 80 scr fill
0 2B8 2B8 400 72B4D 80 scr fill
0 2B9 2B9 400 72B4E 80 scr fill
0 2BA 2BA 400 72B4E 80 scr fill
0 2BB 2BB 400 72B4E 80 scr fill
0 2BC 2BC 400 72B4E 80 scr fill
0 2BD 2BD 400 72B4E 80 scr fill
0 2BE 2BE 400 72B4F 80 scr fill
0 2BF 2BF 400 72B4F 80 scr fill
0 2C0 2C0 400 72B4F 80 scr fill
0 2C1 2C1 400 72B4F 80 scr fill
0 2C2 2C2 400 72B4F 80 scr fill
0 2C3 2C3 400 72B50 80 scr fill
0 2C4 2C4 400 72B50 80 scr fill
0 2C5 2C5 400 72B50 80 scr fill
0 2C6 2C6 400 72B50 80 scr fill
0 2C7 2C7 400 72B50 80 scr fill
0 2C8 2C8 400 72B51 80 scr fill
0 2C9 2C9 400 72B51 80 scr fill
0 2CA 2CA 400 72B51 80 scr fill
0 2CB 2CB 400 72B51 80 scr fill
0 2CC 2CC 400 72B51 80 scr fill
0 2CD 2CD 400 72B52 80 scr fill
0 2CE 2CE 400 72B52 80 scr fill
0 2CF 2CF 400 72B52 80 scr fill
0 2D0 2D0 400 72B52 80 scr fill
0 2D1 2D1 400 72B52 80 scr fill
P List
log log phy length
0 2D2 2D2 400 72B53 80 scr fill
0 2D3 2D3 400 72B53 80 scr fill
0 2D4 2D4 400 72B53 80 scr fill
0 2D5 2D5 400 72B53 80 scr fill
0 2D6 2D6 400 72B53 80 scr fill
0 2D7 2D7 400 72B54 80 scr fill
0 2D8 2D8 400 72B54 80 scr fill
0 2D9 2D9 400 72B54 80 scr fill
0 2DA 2DA 400 72B54 80 scr fill
0 2DB 2DB 400 72B54 80 scr fill
0 2DC 2DC 400 72B55 80 scr fill
0 2DD 2DD 400 72B55 80 scr fill
0 2DE 2DE 400 72B55 80 scr fill
3 90B 90B 401 DF326 80 scr fill
3 90C 90C 401 DF326 80 scr fill
3 90D 90D 401 DF326 80 scr fill
3 90E 90E 401 DF326 80 scr fill
3 90F 90F 401 DF326 80 scr fill
3 910 910 401 DF326 80 scr fill
3 911 911 401 DF326 80 scr fill
3 912 912 401 DF326 80 scr fill
3 913 913 401 DF326 80 scr fill
3 914 914 401 DF326 80 scr fill
3 915 915 401 DF326 80 scr fill
3 916 916 401 DF326 80 scr fill
3 917 917 401 DF325 80 scr fill
3 918 918 401 DF325 80 scr fill
3 919 919 401 DF325 80 scr fill
3 91A 91A 401 DF325 80 scr fill
3 91B 91B 401 DF325 80 scr fill
3 91C 91C 401 DF325 80 scr fill
P List
log log phy length
3 91D 91D 401 DF325 80 scr fill
3 91E 91E 401 DF325 80 scr fill
3 91F 91F 401 DF325 80 scr fill
3 920 920 401 DF325 80 scr fill
3 921 921 401 DF325 80 scr fill
3 922 922 401 DF325 80 scr fill
1 C56 C56 3FD AB8E4 80 scr fill
1 C57 C57 3FD AB8E4 80 scr fill
1 C58 C58 3FD AB8E4 80 scr fill
1 169A 169A 401 D6BAD 80 scr fill
1 169B 169B 401 D6BAD 80 scr fill
1 169C 169C 401 D6BAD 80 scr fill
1 169D 169D 401 D6BAD 80 scr fill
1 169E 169E 401 D6BAD 80 scr fill
1 169F 169F 401 D6BAD 80 scr fill
1 16A0 16A0 401 D6BAD 80 scr fill
1 16A1 16A1 401 D6BAD 80 scr fill
1 16A2 16A2 401 D6BAD 80 scr fill
1 16A3 16A3 401 D6BAD 80 scr fill
1 16A4 16A4 401 D6BAD 80 scr fill
1 16A5 16A5 401 D6BAD 80 scr fill
1 16A6 16A6 401 D6BAD 80 scr fill
3 16FF 16FF 3FD EA101 80 scr fill
3 1700 1700 3FD EA101 80 scr fill
3 1701 1701 3FD EA101 80 scr fill
2 1872 1872 3FF C92C7 80 scr fill
2 1873 1873 3FF C92C7 80 scr fill
2 1874 1874 3FF C92C7 80 scr fill
2 1875 1875 3FF C92C7 80 scr fill
2 1876 1876 3FF C92C7 80 scr fill
2 1877 1877 3FF C92C7 80 scr fill
P List
log log phy length
2 1878 1878 3FF C92C7 80 scr fill
2 1879 1879 3FF C92C7 80 scr fill
2 187A 187A 3FF C92C7 80 scr fill
2 187B 187B 3FF C92C7 80 scr fill
2 187C 187C 3FF C92C7 80 scr fill
2 187D 187D 3FF C92C7 80 scr fill
2 187E 187E 3FF C92C7 80 scr fill
3 1EF4 1EF4 3FE 5D115 80 scr fill
3 1EF5 1EF5 3FE 5D115 80 scr fill
3 1EF6 1EF6 3FE 5D115 80 scr fill
3 2FC9 2FC9 401 E551A 80 scr fill
3 2FCA 2FCA 401 E551A 80 scr fill
3 2FCB 2FCB 401 E551A 80 scr fill
3 2FCC 2FCC 401 E551B 80 scr fill
3 2FCD 2FCD 401 E551B 80 scr fill
3 2FCE 2FCE 401 E551B 80 scr fill
3 2FCF 2FCF 401 E551B 80 scr fill
3 2FD0 2FD0 401 E551B 80 scr fill
3 2FD1 2FD1 401 E551B 80 scr fill
3 2FD2 2FD2 401 E551B 80 scr fill
3 2FD3 2FD3 401 E551B 80 scr fill
3 2FD4 2FD4 401 E551B 80 scr fill
3 2FD5 2FD5 401 E551B 80 scr fill
3 2FD6 2FD6 401 E551B 80 scr fill
3 2FD7 2FD7 401 E551C 80 scr fill
3 2FD8 2FD8 401 E551C 80 scr fill
3 2FD9 2FD9 401 E551C 80 scr fill
3 2FDA 2FDA 401 E551C 80 scr fill
3 2FDB 2FDB 401 E551C 80 scr fill
3 2FDC 2FDC 401 E551C 80 scr fill
3 2FDD 2FDD 401 E551C 80 scr fill
P List
log log phy length
3 2FDE 2FDE 401 E551C 80 scr fill
3 2FDF 2FDF 401 E551C 80 scr fill
3 2FE0 2FE0 401 E551C 80 scr fill
3 2FE1 2FE1 401 E551C 80 scr fill
3 2FE2 2FE2 401 E551C 80 scr fill
3 2FE3 2FE3 401 E551D 80 scr fill
3 2FE4 2FE4 401 E551D 80 scr fill
3 2FE5 2FE5 401 E551D 80 scr fill
3 2FE6 2FE6 401 E551D 80 scr fill
3 2FE7 2FE7 401 E551D 80 scr fill
3 2FE8 2FE8 401 E551D 80 scr fill
3 2FE9 2FE9 401 E551D 80 scr fill
3 2FEA 2FEA 401 E551D 80 scr fill
3 2FEB 2FEB 401 E551D 80 scr fill
3 2FEC 2FEC 401 E551D 80 scr fill
3 2FED 2FED 401 E551D 80 scr fill
3 2FEE 2FEE 401 E551D 80 scr fill
3 2FEF 2FEF 401 E551E 80 scr fill
3 2FF0 2FF0 401 E551E 80 scr fill
3 2FF1 2FF1 401 E551E 80 scr fill
3 2FF2 2FF2 401 E551E 80 scr fill
3 2FF3 2FF3 401 E551E 80 scr fill
3 2FF4 2FF4 401 E551E 80 scr fill
3 31FD 31FD 414 44DFF 80 scr fill
3 31FE 31FE 414 44DFD 80 scr fill
3 31FF 31FF 414 44DFC 80 scr fill
3 3200 3200 414 44DFA 80 scr fill
3 3201 3201 414 44DF8 80 scr fill
3 3202 3202 414 44DF6 80 scr fill
3 3203 3203 414 44DF5 80 scr fill
3 3204 3204 414 44DF3 80 scr fill
P List
log log phy length
3 3205 3205 414 44DF1 80 scr fill
3 3206 3206 414 44DEF 80 scr fill
3 3207 3207 414 44DEE 80 scr fill
3 3208 3208 414 44DEC 80 scr fill
3 3209 3209 414 44DEA 80 scr fill
2 32CC 32CC 3FD 28878 80 scr fill
2 32CD 32CD 3FD 28878 80 scr fill
2 32CE 32CE 3FD 28878 80 scr fill
3 33BC 33BC 3FD BA2D9 80 scr fill
3 33BD 33BD 3FD BA2D9 80 scr fill
3 33BE 33BE 3FD BA2D9 80 scr fill
2 36FB 36FB 3FD 71839 80 scr fill
2 36FC 36FC 3FD 71839 80 scr fill
2 36FD 36FD 3FD 71839 80 scr fill
2 3989 3989 44C B7888 80 scr fill
2 398A 398A 44C B7888 80 scr fill
2 398B 398B 44C B7888 80 scr fill
3 39C8 39C8 400 B15ED 80 scr fill
3 39C9 39C9 400 B15ED 80 scr fill
3 39CA 39CA 400 B15ED 80 scr fill
3 39CB 39CB 400 B15ED 80 scr fill
3 39CC 39CC 400 B15ED 80 scr fill
3 39CD 39CD 400 B15ED 80 scr fill
3 39CE 39CE 400 B15ED 80 scr fill
3 39CF 39CF 400 B15ED 80 scr fill
3 39D0 39D0 400 B15ED 80 scr fill
3 39D1 39D1 400 B15ED 80 scr fill
3 39D2 39D2 400 B15ED 80 scr fill
3 39D3 39D3 400 B15ED 80 scr fill
3 39D4 39D4 400 B15ED 80 scr fill
3 39D5 39D5 400 B15ED 80 scr fill
P List
log log phy length
3 39D6 39D6 400 B15ED 80 scr fill
3 39D7 39D7 400 B15ED 80 scr fill
3 39D8 39D8 400 B15ED 80 scr fill
3 39D9 39D9 400 B15EC 80 scr fill
3 39DA 39DA 400 B15EC 80 scr fill
3 39DB 39DB 400 B15EC 80 scr fill
3 39DC 39DC 400 B15EC 80 scr fill
3 39DD 39DD 400 B15EC 80 scr fill
3 39DE 39DE 400 B15EC 80 scr fill
3 39DF 39DF 400 B15EC 80 scr fill
3 39E0 39E0 400 B15EC 80 scr fill
3 39E1 39E1 400 B15EC 80 scr fill
3 39E2 39E2 400 B15EC 80 scr fill
3 39E3 39E3 400 B15EC 80 scr fill
3 39E4 39E4 400 B15EC 80 scr fill
3 39E5 39E5 400 B15EC 80 scr fill
3 39E6 39E6 400 B15EC 80 scr fill
3 39E7 39E7 400 B15EC 80 scr fill
3 39E8 39E8 400 B15EC 80 scr fill
3 39E9 39E9 400 B15EC 80 scr fill
3 39EA 39EA 400 B15EC 80 scr fill
3 39EB 39EB 400 B15EC 80 scr fill
3 39EC 39EC 400 B15EC 80 scr fill
3 39ED 39ED 400 B15EB 80 scr fill
3 39EE 39EE 400 B15EB 80 scr fill
3 39EF 39EF 400 B15EB 80 scr fill
3 39F0 39F0 400 B15EB 80 scr fill
3 439D 439D 2 E3419 80 scr fill
3 439E 439E 2 E341A 80 scr fill
3 439F 439F 3 E341A 80 scr fill
3 43A0 43A0 2 E341B 80 scr fill
P List
log log phy length
3 43A1 43A1 2 E341C 80 scr fill
3 43A2 43A2 3 E341C 80 scr fill
3 43A3 43A3 2 E341D 80 scr fill
3 43A4 43A4 3 E341D 80 scr fill
3 43A5 43A5 2 E341E 80 scr fill
3 43A6 43A6 2 E341F 80 scr fill
3 43A7 43A7 3 E341F 80 scr fill
2 43A8 43A8 3FD 2C2C5 80 scr fill
3 43A8 43A8 2 E3420 80 scr fill
2 43A9 43A9 3FD 2C2C5 80 scr fill
3 43A9 43A9 2 E3421 80 scr fill
2 43AA 43AA 3FD 2C2C5 80 scr fill
3 43AA 43AA 2 E3421 80 scr fill
3 43AB 43AB 2 E3422 80 scr fill
3 43AC 43AC 3 E3422 80 scr fill
3 43AD 43AD 2 E3423 80 scr fill
3 43AE 43AE 2 E3424 80 scr fill
3 43AF 43AF 3 E3424 80 scr fill
3 43B0 43B0 2 E3425 80 scr fill
3 43B1 43B1 3 E3425 80 scr fill
3 43B2 43B2 2 E3426 80 scr fill
3 43B3 43B3 2 E3427 80 scr fill
3 43B4 43B4 3 E3427 80 scr fill
3 43B5 43B5 2 E3428 80 scr fill
3 43B6 43B6 2 E3429 80 scr fill
3 43B7 43B7 2 E3429 80 scr fill
3 43B8 43B8 2 E342A 80 scr fill
3 43B9 43B9 3 E342A 80 scr fill
3 43BA 43BA 2 E342B 80 scr fill
3 43BB 43BB 2 E342C 80 scr fill
3 43BC 43BC 2 E342C 80 scr fill
P List
log log phy length
3 43BD 43BD 2 E342D 80 scr fill
3 43BE 43BE 3 E342D 80 scr fill
3 43BF 43BF 2 E342E 80 scr fill
3 43C0 43C0 2 E342F 80 scr fill
3 43C1 43C1 2 E342F 80 scr fill
3 43C2 43C2 2 E3430 80 scr fill
3 43C3 43C3 2 E3431 80 scr fill
3 43C4 43C4 2 E3431 80 scr fill
3 43C5 43C5 2 E3432 80 scr fill
3 43C6 43C6 3 E3432 80 scr fill
3 43C7 43C7 2 E3433 80 scr fill
3 43C8 43C8 2 E3434 80 scr fill
3 43C9 43C9 2 E3434 80 scr fill
3 43CA 43CA 2 E3435 80 scr fill
3 43CB 43CB 3 E3435 80 scr fill
3 43CC 43CC 2 E3436 80 scr fill
3 43CD 43CD 2 E3437 80 scr fill
3 43CE 43CE 2 E3437 80 scr fill
3 43CF 43CF 2 E3438 80 scr fill
3 43D0 43D0 3 E3438 80 scr fill
3 43D1 43D1 2 E3439 80 scr fill
3 43D2 43D2 2 E343A 80 scr fill
3 43D3 43D3 2 E343A 80 scr fill
3 43D4 43D4 2 E343B 80 scr fill
3 43D5 43D5 2 E343C 80 scr fill
3 43D6 43D6 2 E343C 80 scr fill
3 43D7 43D7 2 E343D 80 scr fill
3 43D8 43D8 2 E343D 80 scr fill
3 43D9 43D9 2 E343E 80 scr fill
3 43DA 43DA 2 E343F 80 scr fill
3 43DB 43DB 2 E343F 80 scr fill
P List
log log phy length
3 43DC 43DC 2 E3440 80 scr fill
3 43DD 43DD 3 E3440 80 scr fill
3 43DE 43DE 2 E3441 80 scr fill
3 43DF 43DF 2 E3442 80 scr fill
3 43E0 43E0 2 E3442 80 scr fill
3 43E1 43E1 2 E3443 80 scr fill
3 43E2 43E2 2 E3444 80 scr fill
3 43E3 43E3 2 E3444 80 scr fill
3 43E4 43E4 2 E3445 80 scr fill
3 43E5 43E5 2 E3445 80 scr fill
3 43E6 43E6 2 E3446 80 scr fill
3 43E7 43E7 2 E3447 80 scr fill
3 43E8 43E8 2 E3447 80 scr fill
3 43E9 43E9 2 E3448 80 scr fill
3 43EA 43EA 2 E3448 80 scr fill
3 43EB 43EB 2 E3449 80 scr fill
3 43EC 43EC 2 E344A 80 scr fill
3 43ED 43ED 2 E344A 80 scr fill
3 43EE 43EE 2 E344B 80 scr fill
3 43EF 43EF 3 E344B 80 scr fill
3 43F0 43F0 2 E344C 80 scr fill
3 43F1 43F1 2 E344D 80 scr fill
3 43F2 43F2 2 E344D 80 scr fill
3 43F3 43F3 2 E344E 80 scr fill
3 43F4 43F4 2 E344F 80 scr fill
3 43F5 43F5 2 E344F 80 scr fill
3 43F6 43F6 2 E3450 80 scr fill
3 43F7 43F7 2 E3450 80 scr fill
3 43F8 43F8 2 E3451 80 scr fill
3 43F9 43F9 2 E3452 80 scr fill
3 43FA 43FA 2 E3452 80 scr fill
P List
log log phy length
3 43FB 43FB 2 E3453 80 scr fill
3 43FC 43FC 3 E3453 80 scr fill
3 43FD 43FD 2 E3454 80 scr fill
3 43FE 43FE 2 E3455 80 scr fill
3 43FF 43FF 2 E3455 80 scr fill
3 4400 4400 2 E3456 80 scr fill
3 4401 4401 3 E3456 80 scr fill
3 4402 4402 2 E3457 80 scr fill
3 4403 4403 2 E3458 80 scr fill
3 4404 4404 2 E3458 80 scr fill
3 4405 4405 2 E3459 80 scr fill
3 4406 4406 3 E3459 80 scr fill
3 4407 4407 2 E345A 80 scr fill
3 4408 4408 2 E345B 80 scr fill
3 4409 4409 2 E345B 80 scr fill
3 440A 440A 2 E345C 80 scr fill
3 440B 440B 2 E345D 80 scr fill
3 440C 440C 2 E345D 80 scr fill
3 440D 440D 2 E345E 80 scr fill
3 440E 440E 3 E345E 80 scr fill
3 440F 440F 2 E345F 80 scr fill
3 4410 4410 2 E3460 80 scr fill
3 4411 4411 2 E3460 80 scr fill
3 4412 4412 2 E3461 80 scr fill
3 4413 4413 3 E3461 80 scr fill
3 4414 4414 2 E3462 80 scr fill
3 4415 4415 2 E3463 80 scr fill
3 4416 4416 2 E3463 80 scr fill
3 4417 4417 2 E3464 80 scr fill
3 4418 4418 3 E3464 80 scr fill
3 4419 4419 2 E3465 80 scr fill
P List
log log phy length
3 441A 441A 2 E3466 80 scr fill
3 441B 441B 3 E3466 80 scr fill
3 441C 441C 2 E3467 80 scr fill
3 441D 441D 3 E3467 80 scr fill
3 441E 441E 2 E3468 80 scr fill
3 441F 441F 2 E3469 80 scr fill
3 4420 4420 3 E3469 80 scr fill
3 4421 4421 2 E346A 80 scr fill
3 4422 4422 2 E346B 80 scr fill
3 4423 4423 2 E346B 80 scr fill
3 4424 4424 2 E346C 80 scr fill
3 4425 4425 3 E346C 80 scr fill
3 4426 4426 2 E346D 80 scr fill
3 4427 4427 3FE E326E 80 scr fill
3 4428 4428 3FE E326F 80 scr fill
3 4429 4429 3FE E3270 80 scr fill
3 442A 442A 3FE E3271 80 scr fill
3 442B 442B 3FE E3272 80 scr fill
3 442C 442C 3FE E3273 80 scr fill
3 442D 442D 3FE E3274 80 scr fill
3 442E 442E 3FE E3275 80 scr fill
3 442F 442F 3FE E3276 80 scr fill
3 4430 4430 3FE E3277 80 scr fill
3 4431 4431 2 E3474 80 scr fill
3 4432 4432 3 E3474 80 scr fill
3 4433 4433 2 E3475 80 scr fill
3 4434 4434 3 E3475 80 scr fill
3 4435 4435 3 E3476 80 scr fill
3 4436 4436 2 E3477 80 scr fill
3 4437 4437 3 E3477 80 scr fill
3 4438 4438 2 E3478 80 scr fill
P List
log log phy length
3 4439 4439 2 E3479 80 scr fill
3 443A 443A 3 E3479 80 scr fill
3 443B 443B 2 E347A 80 scr fill
3 443C 443C 3 E347A 80 scr fill
3 443D 443D 2 E347B 80 scr fill
3 443E 443E 2 E347C 80 scr fill
3 443F 443F 3 E347C 80 scr fill
3 4440 4440 2 E347D 80 scr fill
3 4441 4441 3 E347D 80 scr fill
3 4442 4442 2 E347E 80 scr fill
3 4443 4443 2 E347F 80 scr fill
3 4444 4444 3 E347F 80 scr fill
3 4445 4445 2 E3480 80 scr fill
3 4446 4446 3 E3480 80 scr fill
3 4447 4447 3 E3481 80 scr fill
3 4448 4448 2 E3482 80 scr fill
3 4449 4449 3 E3482 80 scr fill
3 444A 444A 2 E3483 80 scr fill
3 444B 444B 3 E3483 80 scr fill
3 444C 444C 3 E3484 80 scr fill
3 444D 444D 2 E3485 80 scr fill
3 444E 444E 3 E3485 80 scr fill
3 444F 444F 2 E3486 80 scr fill
3 4450 4450 2 E3487 80 scr fill
3 4451 4451 3 E3487 80 scr fill
3 4452 4452 2 E3488 80 scr fill
3 4453 4453 3 E3488 80 scr fill
3 4454 4454 3 E3489 80 scr fill
3 4455 4455 2 E348A 80 scr fill
3 4456 4456 3 E348A 80 scr fill
3 4457 4457 2 E348B 80 scr fill
P List
log log phy length
3 4458 4458 3 E348B 80 scr fill
3 4459 4459 3 E348C 80 scr fill
3 445A 445A 2 E348D 80 scr fill
3 445B 445B 3 E348D 80 scr fill
3 445C 445C 2 E348E 80 scr fill
3 445D 445D 3 E348E 80 scr fill
3 445E 445E 3 E348F 80 scr fill
3 445F 445F 2 E3490 80 scr fill
3 4460 4460 3 E3490 80 scr fill
3 4461 4461 3 E3491 80 scr fill
3 4462 4462 3 E3491 80 scr fill
3 4463 4463 3 E3492 80 scr fill
3 4464 4464 2 E3493 80 scr fill
3 4465 4465 3 E3493 80 scr fill
3 4466 4466 3 E3494 80 scr fill
3 4467 4467 2 E3495 80 scr fill
3 4468 4468 3 E3495 80 scr fill
3 4469 4469 2 E3496 80 scr fill
3 446A 446A 3 E3496 80 scr fill
3 446B 446B 3 E3497 80 scr fill
3 446C 446C 2 E3498 80 scr fill
3 446D 446D 3 E3498 80 scr fill
3 446E 446E 3 E3499 80 scr fill
3 446F 446F 3 E3499 80 scr fill
3 4470 4470 3 E349A 80 scr fill
3 4471 4471 2 E349B 80 scr fill
3 4472 4472 3 E349B 80 scr fill
3 4473 4473 3 E349C 80 scr fill
3 4474 4474 2 E349D 80 scr fill
3 4475 4475 2 E349E 80 scr fill
0 459F 459F 3FD DB450 80 scr fill
P List
log log phy length
0 45A0 45A0 3FD DB450 80 scr fill
0 45A1 45A1 3FD DB450 80 scr fill
3 4D0F 4D0F 3FF E2868 80 scr fill
3 4D10 4D10 3FF E2868 80 scr fill
3 4D11 4D11 3FF E2869 80 scr fill
3 4D12 4D12 3FF E2869 80 scr fill
3 4D13 4D13 3FF E286A 80 scr fill
3 4D14 4D14 3FF E286A 80 scr fill
3 4D15 4D15 3FF E286B 80 scr fill
3 4D16 4D16 3FF E286B 80 scr fill
3 4D17 4D17 3FF E286C 80 scr fill
3 4D18 4D18 3FF E286C 80 scr fill
0 4D98 4D98 3FD 14A21 80 scr fill
0 4D99 4D99 3FD 14A21 80 scr fill
0 4D9A 4D9A 3FD 14A21 80 scr fill
0 4D9B 4D9B 3FD 14A21 80 scr fill
0 4D9C 4D9C 3FD 14A21 80 scr fill
0 4D9D 4D9D 3FD 14A21 80 scr fill
0 4D9E 4D9E 3FD 14A21 80 scr fill
0 4D9F 4D9F 3FD 14A21 80 scr fill
0 4DA0 4DA0 3FD 14A21 80 scr fill
0 4DA1 4DA1 3FD 14A21 80 scr fill
0 4DA2 4DA2 3FD 14A21 80 scr fill
0 4DA3 4DA3 3FD 14A21 80 scr fill
0 4DA4 4DA4 3FD 14A21 80 scr fill
0 4DA5 4DA5 3FD 14A21 80 scr fill
0 4DA6 4DA6 3FD 14A21 80 scr fill
0 4DA7 4DA7 3FD 14A21 80 scr fill
0 4DA8 4DA8 3FD 14A21 80 scr fill
0 4DA9 4DA9 3FD 14A21 80 scr fill
0 4DAA 4DAA 3FD 14A21 80 scr fill
P List
log log phy length
0 4DAB 4DAB 3FD 14A21 80 scr fill
0 4DAC 4DAC 3FD 14A21 80 scr fill
0 4DAD 4DAD 3FD 14A21 80 scr fill
0 4DAE 4DAE 3FD 14A21 80 scr fill
0 4DAF 4DAF 3FD 14A21 80 scr fill
0 4DB0 4DB0 3FD 14A21 80 scr fill
0 4DB1 4DB1 3FD 14A21 80 scr fill
0 4DB2 4DB2 3FD 14A21 80 scr fill
0 4DB3 4DB3 3FD 14A21 80 scr fill
0 4DB4 4DB4 3FD 14A21 80 scr fill
0 4DB5 4DB5 3FD 14A21 80 scr fill
0 4DB6 4DB6 3FD 14A21 80 scr fill
0 4DB7 4DB7 3FD 14A21 80 scr fill
0 4DB8 4DB8 3FD 14A21 80 scr fill
0 4DB9 4DB9 3FD 14A21 80 scr fill
0 4DBA 4DBA 3FD 14A21 80 scr fill
0 4DBB 4DBB 3FD 14A21 80 scr fill
0 4DBC 4DBC 3FD 14A21 80 scr fill
0 4DBD 4DBD 3FD 14A21 80 scr fill
0 4DBE 4DBE 3FD 14A21 80 scr fill
0 4DBF 4DBF 3FD 14A21 80 scr fill
0 4DC0 4DC0 3FD 14A21 80 scr fill
2 5088 5088 3FD A02E 80 scr fill
2 5089 5089 3FD A02E 80 scr fill
2 508A 508A 3FD A02E 80 scr fill
2 5113 5113 3FD 2F111 80 scr fill
2 5114 5114 3FD 2F111 80 scr fill
2 5115 5115 3FD 2F111 80 scr fill
0 53A3 53A3 3FD A9709 80 scr fill
0 53A4 53A4 3FD A9709 80 scr fill
0 53A5 53A5 3FD A9709 80 scr fill
P List
log log phy length
2 53A5 53A5 416 271E3 80 scr fill
2 53A6 53A6 416 271E3 80 scr fill
2 53A7 53A7 416 271E3 80 scr fill
3 5910 5910 3FD C2FF9 80 scr fill
3 5911 5911 3FD C2FF9 80 scr fill
3 5912 5912 3FD C2FF9 80 scr fill
3 60A2 60A2 3FE E3BC2 80 scr fill
3 60A3 60A3 3FE E3BC2 80 scr fill
3 60A4 60A4 3FE E3BC2 80 scr fill
3 60A5 60A5 3FE E3BC2 80 scr fill
3 60A6 60A6 3FE E3BC2 80 scr fill
3 60A7 60A7 3FE E3BC2 80 scr fill
3 60A8 60A8 3FE E3BC2 80 scr fill
3 60A9 60A9 3FE E3BC2 80 scr fill
3 60AA 60AA 3FE E3BC2 80 scr fill
3 60AB 60AB 3FE E3BC2 80 scr fill
1 672C 672C 400 DDAA7 80 scr fill
1 672D 672D 400 DDAA8 80 scr fill
1 672E 672E 400 DDAA8 80 scr fill
1 672F 672F 400 DDAA9 80 scr fill
1 6730 6730 400 DDAA9 80 scr fill
1 6731 6731 400 DDAA9 80 scr fill
1 6732 6732 400 DDAAA 80 scr fill
1 6733 6733 400 DDAAA 80 scr fill
1 6734 6734 400 DDAAA 80 scr fill
1 6735 6735 400 DDAAB 80 scr fill
1 6736 6736 400 DDAAB 80 scr fill
1 6737 6737 400 DDAAB 80 scr fill
1 6738 6738 400 DDAAC 80 scr fill
1 6739 6739 400 DDAAC 80 scr fill
1 673A 673A 400 DDAAC 80 scr fill
P List
log log phy length
1 673B 673B 400 DDAAD 80 scr fill
1 673C 673C 400 DDAAD 80 scr fill
1 673D 673D 400 DDAAD 80 scr fill
1 673E 673E 400 DDAAE 80 scr fill
1 673F 673F 400 DDAAE 80 scr fill
1 6740 6740 400 DDAAF 80 scr fill
1 6741 6741 400 DDAAF 80 scr fill
1 6742 6742 400 DDAAF 80 scr fill
1 6743 6743 400 DDAB0 80 scr fill
2 6823 6823 3FD CCF2C 80 scr fill
2 6824 6824 3FD CCF2C 80 scr fill
2 6825 6825 3FD CCF2C 80 scr fill
0 6D71 6D71 404 8359F 80 scr fill
0 6D72 6D72 404 835A0 80 scr fill
0 6D73 6D73 404 835A0 80 scr fill
0 6D74 6D74 404 835A1 80 scr fill
0 6D75 6D75 404 835A2 80 scr fill
0 6D76 6D76 404 835A2 80 scr fill
0 6D77 6D77 404 835A3 80 scr fill
0 6D78 6D78 404 835A4 80 scr fill
0 6D79 6D79 404 835A4 80 scr fill
0 6D7A 6D7A 404 835A5 80 scr fill
0 6D7B 6D7B 404 835A6 80 scr fill
0 6D7C 6D7C 404 835A7 80 scr fill
0 6D7D 6D7D 404 835A7 80 scr fill
0 6D7E 6D7E 404 835A8 80 scr fill
0 6D7F 6D7F 404 835A9 80 scr fill
0 6D80 6D80 404 835A9 80 scr fill
0 6D81 6D81 404 835AA 80 scr fill
0 6D82 6D82 404 835AB 80 scr fill
0 6D83 6D83 404 835AB 80 scr fill
P List
log log phy length
0 6D84 6D84 404 835AC 80 scr fill
0 6D85 6D85 404 835AD 80 scr fill
0 6D86 6D86 404 835AE 80 scr fill
0 6D87 6D87 404 835AE 80 scr fill
0 6D88 6D88 404 835AF 80 scr fill
2 77EC 77EC 3FD B7F32 80 scr fill
2 77ED 77ED 3FD B7F32 80 scr fill
2 77EE 77EE 3FD B7F32 80 scr fill
2 84F6 84F6 3FD 592F2 80 scr fill
2 84F7 84F7 3FD 592F2 80 scr fill
2 84F8 84F8 3FD 592F2 80 scr fill
1 8BA2 8BA2 401 16240 80 scr fill
1 8BA3 8BA3 401 16241 80 scr fill
1 8BA4 8BA4 401 16241 80 scr fill
1 8BA5 8BA5 401 16241 80 scr fill
1 8BA6 8BA6 401 16241 80 scr fill
1 8BA7 8BA7 401 16242 80 scr fill
1 8BA8 8BA8 401 16242 80 scr fill
1 8BA9 8BA9 401 16242 80 scr fill
1 8BAA 8BAA 401 16242 80 scr fill
1 8BAB 8BAB 401 16243 80 scr fill
1 8BAC 8BAC 401 16243 80 scr fill
1 8BAD 8BAD 401 16243 80 scr fill
1 8BAE 8BAE 401 16243 80 scr fill
1 8BAF 8BAF 401 16244 80 scr fill
1 8BB0 8BB0 401 16244 80 scr fill
1 8BB1 8BB1 401 16244 80 scr fill
1 8BB2 8BB2 401 16244 80 scr fill
1 8BB3 8BB3 401 16245 80 scr fill
1 8BB4 8BB4 401 16245 80 scr fill
1 8BB5 8BB5 401 16245 80 scr fill
P List
log log phy length
1 8BB6 8BB6 401 16245 80 scr fill
1 8BB7 8BB7 401 16246 80 scr fill
1 8BB8 8BB8 401 16246 80 scr fill
1 8BB9 8BB9 401 16246 80 scr fill
2 8FC0 8FC0 3FD AA42A 80 scr fill
2 8FC1 8FC1 3FD AA42A 80 scr fill
2 8FC2 8FC2 3FD AA42A 80 scr fill
1 9080 9080 3FD E65E 80 scr fill
1 9081 9081 3FD E65E 80 scr fill
1 9082 9082 3FD E65E 80 scr fill
2 950A 950A 3FD 2E4BA 80 scr fill
2 950B 950B 3FD 2E4BA 80 scr fill
2 950C 950C 3FD 2E4BA 80 scr fill
1 9F23 9F23 3FD 4E54A 80 scr fill
1 9F24 9F24 3FD 4E54A 80 scr fill
1 9F25 9F25 3FD 4E54A 80 scr fill
0 A039 A039 400 1744 80 scr fill
0 A03A A03A 400 1744 80 scr fill
0 A03B A03B 400 1744 80 scr fill
0 A03C A03C 400 1744 80 scr fill
0 A03D A03D 400 1744 80 scr fill
0 A03E A03E 400 1744 80 scr fill
0 A03F A03F 400 1744 80 scr fill
0 A040 A040 400 1744 80 scr fill
0 A041 A041 400 1744 80 scr fill
0 A042 A042 400 1744 80 scr fill
0 A043 A043 400 1744 80 scr fill
0 A044 A044 400 1744 80 scr fill
0 A045 A045 400 1743 80 scr fill
0 A046 A046 400 1743 80 scr fill
0 A047 A047 400 1743 80 scr fill
P List
log log phy length
0 A048 A048 400 1743 80 scr fill
0 A049 A049 400 1743 80 scr fill
0 A04A A04A 400 1743 80 scr fill
0 A04B A04B 400 1743 80 scr fill
0 A04C A04C 400 1743 80 scr fill
0 A04D A04D 400 1743 80 scr fill
0 A04E A04E 400 1743 80 scr fill
0 A04F A04F 400 1743 80 scr fill
0 A050 A050 400 1743 80 scr fill
2 B02E B02E C6 448A7 80 scr fill
2 B02F B02F 1B5 447B8 80 scr fill
2 B030 B030 2A3 446CA 80 scr fill
2 B031 B031 391 445DC 80 scr fill
2 B032 B032 47F 444EE 80 scr fill
2 B033 B033 56D 44400 80 scr fill
2 B034 B034 647 44312 80 scr fill
2 B035 B035 647 44224 80 scr fill
2 B036 B036 647 44135 80 scr fill
2 B037 B037 647 44047 80 scr fill
2 B038 B038 647 43F59 80 scr fill
2 B039 B039 647 43E6B 80 scr fill
2 B03A B03A 647 43D7D 80 scr fill
2 B03B B03B 647 43C8F 80 scr fill
2 B03C B03C 647 43BA1 80 scr fill
2 B03D B03D 647 43AB3 80 scr fill
2 B03E B03E 647 439C4 80 scr fill
2 B03F B03F 647 438D6 80 scr fill
2 B040 B040 647 437E8 80 scr fill
2 B041 B041 647 436FA 80 scr fill
2 B042 B042 647 4360C 80 scr fill
2 B043 B043 647 4351E 80 scr fill
P List
log log phy length
2 B044 B044 647 43430 80 scr fill
2 B045 B045 647 43341 80 scr fill
2 B046 B046 647 43253 80 scr fill
2 B047 B047 647 43165 80 scr fill
2 B048 B048 647 43077 80 scr fill
2 B049 B049 647 42F89 80 scr fill
2 B04A B04A 647 42E9B 80 scr fill
2 B04B B04B 5D9 42E1A 80 scr fill
2 B04C B04C 4EB 42E1A 80 scr fill
2 B04D B04D 3FD 42E1A 80 scr fill
2 B04E B04E 30F 42E1A 80 scr fill
2 B04F B04F 221 42E1A 80 scr fill
2 B050 B050 133 42E1A 80 scr fill
2 B051 B051 45 42E1A 80 scr fill
3 BC14 BC14 400 D40C1 80 scr fill
3 BC15 BC15 400 D40C1 80 scr fill
3 BC16 BC16 400 D40C1 80 scr fill
3 BC17 BC17 400 D40C1 80 scr fill
3 BC18 BC18 400 D40C1 80 scr fill
3 BC19 BC19 400 D40C1 80 scr fill
3 BC1A BC1A 400 D40C1 80 scr fill
3 BC1B BC1B 400 D40C1 80 scr fill
3 BC1C BC1C 400 D40C1 80 scr fill
3 BC1D BC1D 400 D40C1 80 scr fill
1 C56C C56C 3FD C057F 80 scr fill
1 C56D C56D 3FD C057F 80 scr fill
1 C56E C56E 3FD C057F 80 scr fill
2 C696 C696 3FD 1C4CE 80 scr fill
2 C697 C697 3FD 1C4CE 80 scr fill
2 C698 C698 3FD 1C4CE 80 scr fill
3 CB69 CB69 401 489D7 80 scr fill
P List
log log phy length
3 CB6A CB6A 401 489D8 80 scr fill
3 CB6B CB6B 401 489D9 80 scr fill
3 CB6C CB6C 401 489D9 80 scr fill
3 CB6D CB6D 401 489DA 80 scr fill
3 CB6E CB6E 401 489DB 80 scr fill
3 CB6F CB6F 401 489DC 80 scr fill
3 CB70 CB70 401 489DC 80 scr fill
3 CB71 CB71 401 489DD 80 scr fill
3 CB72 CB72 401 489DE 80 scr fill
3 CB73 CB73 401 489DF 80 scr fill
3 CB74 CB74 401 489DF 80 scr fill
3 CB75 CB75 401 489E0 80 scr fill
2 DDCE DDCE 3FD 7C25F 80 scr fill
2 DDCF DDCF 3FD 7C25F 80 scr fill
2 DDD0 DDD0 3FD 7C25F 80 scr fill
0 E261 E261 40B 6AD15 80 scr fill
0 E262 E262 40B 6AD15 80 scr fill
0 E263 E263 40B 6AD15 80 scr fill
0 E264 E264 40B 6AD15 80 scr fill
0 E265 E265 40B 6AD15 80 scr fill
0 E266 E266 40B 6AD15 80 scr fill
0 E267 E267 40B 6AD15 80 scr fill
0 E268 E268 40B 6AD15 80 scr fill
0 E269 E269 40B 6AD15 80 scr fill
0 E26A E26A 40B 6AD15 80 scr fill
0 E26B E26B 40B 6AD15 80 scr fill
0 E26C E26C 40B 6AD15 80 scr fill
0 E26D E26D 40B 6AD14 80 scr fill
0 E26E E26E 40B 6AD14 80 scr fill
0 E26F E26F 40B 6AD14 80 scr fill
0 E270 E270 40B 6AD14 80 scr fill
P List
log log phy length
0 E271 E271 40B 6AD14 80 scr fill
0 E272 E272 40B 6AD14 80 scr fill
0 E273 E273 40B 6AD14 80 scr fill
0 E274 E274 40B 6AD14 80 scr fill
0 E275 E275 40B 6AD14 80 scr fill
0 E276 E276 40B 6AD14 80 scr fill
0 E277 E277 40B 6AD14 80 scr fill
0 E278 E278 40B 6AD14 80 scr fill
0 E279 E279 40B 6AD14 80 scr fill
0 E27A E27A 40B 6AD14 80 scr fill
0 E27B E27B 40B 6AD14 80 scr fill
0 E27C E27C 40B 6AD14 80 scr fill
0 E27D E27D 40B 6AD14 80 scr fill
0 E27E E27E 40B 6AD14 80 scr fill
0 E27F E27F 40B 6AD14 80 scr fill
0 E280 E280 40B 6AD14 80 scr fill
0 E281 E281 40B 6AD14 80 scr fill
0 E282 E282 40B 6AD14 80 scr fill
0 E283 E283 40B 6AD14 80 scr fill
0 E284 E284 40B 6AD14 80 scr fill
0 E285 E285 40B 6AD14 80 scr fill
0 E286 E286 40B 6AD14 80 scr fill
0 E287 E287 40B 6AD14 80 scr fill
0 E288 E288 40B 6AD14 80 scr fill
0 E289 E289 40B 6AD14 80 scr fill
0 E28A E28A 40B 6AD14 80 scr fill
0 E28B E28B 40B 6AD14 80 scr fill
0 E28C E28C 40B 6AD14 80 scr fill
0 E28D E28D 40B 6AD14 80 scr fill
0 E28E E28E 40B 6AD14 80 scr fill
0 E28F E28F 40B 6AD14 80 scr fill
P List
log log phy length
0 E290 E290 40B 6AD14 80 scr fill
0 E291 E291 40B 6AD14 80 scr fill
0 E292 E292 40B 6AD14 80 scr fill
0 E293 E293 40B 6AD14 80 scr fill
0 E294 E294 40B 6AD14 80 scr fill
0 E295 E295 40B 6AD14 80 scr fill
0 E296 E296 40B 6AD14 80 scr fill
0 E297 E297 40B 6AD14 80 scr fill
0 E298 E298 40B 6AD14 80 scr fill
0 E299 E299 40B 6AD14 80 scr fill
0 E29A E29A 40B 6AD14 80 scr fill
0 E29B E29B 40B 6AD14 80 scr fill
0 E29C E29C 40B 6AD14 80 scr fill
0 E29D E29D 40B 6AD14 80 scr fill
0 E29E E29E 40B 6AD14 80 scr fill
0 E29F E29F 40B 6AD14 80 scr fill
0 E2A0 E2A0 40B 6AD14 80 scr fill
0 E2A1 E2A1 40B 6AD14 80 scr fill
0 E2A2 E2A2 40B 6AD14 80 scr fill
0 E2A3 E2A3 40B 6AD14 80 scr fill
0 E2A4 E2A4 40B 6AD14 80 scr fill
0 E2A5 E2A5 40B 6AD14 80 scr fill
0 E2A6 E2A6 40B 6AD14 80 scr fill
0 E2A7 E2A7 40B 6AD14 80 scr fill
0 E2A8 E2A8 40B 6AD14 80 scr fill
2 F2E0 F2E0 3FD 2BF76 80 scr fill
2 F2E1 F2E1 3FD 2BF76 80 scr fill
2 F2E2 F2E2 3FD 2BF76 80 scr fill
0 F7B1 F7B1 402 A79CC 80 scr fill
0 F7B2 F7B2 402 A79CC 80 scr fill
0 F7B3 F7B3 402 A79CC 80 scr fill
P List
log log phy length
0 F7B4 F7B4 402 A79CC 80 scr fill
0 F7B5 F7B5 402 A79CC 80 scr fill
0 F7B6 F7B6 402 A79CC 80 scr fill
0 F7B7 F7B7 402 A79CC 80 scr fill
0 F7B8 F7B8 402 A79CC 80 scr fill
0 F7B9 F7B9 402 A79CC 80 scr fill
0 F7BA F7BA 402 A79CB 80 scr fill
0 F7BB F7BB 402 A79CB 80 scr fill
0 F7BC F7BC 402 A79CB 80 scr fill
0 F7BD F7BD 402 A79CB 80 scr fill
0 F7BE F7BE 402 A79CB 80 scr fill
0 F7BF F7BF 402 A79CB 80 scr fill
0 F7C0 F7C0 402 A79CB 80 scr fill
0 F7C1 F7C1 402 A79CB 80 scr fill
0 F7C2 F7C2 402 A79CB 80 scr fill
0 F7C3 F7C3 402 A79CB 80 scr fill
0 F7C4 F7C4 402 A79CB 80 scr fill
0 F7C5 F7C5 402 A79CB 80 scr fill
0 F7C6 F7C6 402 A79CB 80 scr fill
0 F7C7 F7C7 402 A79CB 80 scr fill
0 F7C8 F7C8 402 A79CB 80 scr fill
0 F7C9 F7C9 402 A79CB 80 scr fill
0 F7CA F7CA 402 A79CB 80 scr fill
0 F7CB F7CB 402 A79CB 80 scr fill
0 F7CC F7CC 402 A79CB 80 scr fill
0 F7CD F7CD 402 A79CB 80 scr fill
0 F7CE F7CE 402 A79CB 80 scr fill
0 F7CF F7CF 402 A79CB 80 scr fill
0 F7D0 F7D0 402 A79CB 80 scr fill
0 F7D1 F7D1 402 A79CB 80 scr fill
0 F7D2 F7D2 402 A79CB 80 scr fill
P List
log log phy length
0 F7D3 F7D3 402 A79CB 80 scr fill
0 F7D4 F7D4 402 A79CB 80 scr fill
0 F7D5 F7D5 402 A79CB 80 scr fill
0 F7D6 F7D6 402 A79CB 80 scr fill
0 F7D7 F7D7 402 A79CB 80 scr fill
0 F7D8 F7D8 402 A79CB 80 scr fill
0 F7D9 F7D9 402 A79CB 80 scr fill
0 F7DA F7DA 402 A79CB 80 scr fill
0 F7DB F7DB 402 A79CB 80 scr fill
0 F7DC F7DC 402 A79CB 80 scr fill
2 FB00 FB00 3FD B1FE 80 scr fill
2 FB01 FB01 3FD B1FE 80 scr fill
2 FB02 FB02 3FD B1FE 80 scr fill
3 11916 11916 3FD 23089 80 scr fill
3 11917 11917 3FD 23089 80 scr fill
3 11918 11918 3FD 23089 80 scr fill
2 119D3 119D3 3FD B7704 80 scr fill
2 119D4 119D4 3FD B7704 80 scr fill
2 119D5 119D5 3FD B7704 80 scr fill
1 11D52 11D52 3FD D2F1 80 scr fill
1 11D53 11D53 3FD D2F1 80 scr fill
1 11D54 11D54 3FD D2F1 80 scr fill
2 11ECF 11ECF 3FD 2118E 80 scr fill
2 11ED0 11ED0 3FD 2118E 80 scr fill
2 11ED1 11ED1 3FD 2118E 80 scr fill
3 13B30 13B30 40A AF72D 80 scr fill
3 13B31 13B31 40A AF72D 80 scr fill
3 13B32 13B32 40A AF72D 80 scr fill
3 13B33 13B33 40A AF72D 80 scr fill
3 13B34 13B34 40A AF72D 80 scr fill
3 13B35 13B35 40A AF72D 80 scr fill
P List
log log phy length
3 13B36 13B36 40A AF72D 80 scr fill
3 13B37 13B37 40A AF72E 80 scr fill
3 13B38 13B38 40A AF72E 80 scr fill
3 13B39 13B39 40A AF72E 80 scr fill
3 13B3A 13B3A 40A AF72E 80 scr fill
3 13B3B 13B3B 40A AF72E 80 scr fill
3 13B3C 13B3C 40A AF72E 80 scr fill
3 13B3D 13B3D 40A AF72E 80 scr fill
3 13B3E 13B3E 40A AF72E 80 scr fill
3 13B3F 13B3F 40A AF72E 80 scr fill
3 13B40 13B40 40A AF72E 80 scr fill
3 13B41 13B41 40A AF72E 80 scr fill
3 13B42 13B42 40A AF72E 80 scr fill
3 13B43 13B43 40A AF72E 80 scr fill
3 13B44 13B44 40A AF72E 80 scr fill
3 13B45 13B45 40A AF72E 80 scr fill
3 13B46 13B46 40A AF72E 80 scr fill
3 13B47 13B47 40A AF72E 80 scr fill
3 13B48 13B48 40A AF72E 80 scr fill
3 13B49 13B49 40A AF72E 80 scr fill
3 13B4A 13B4A 40A AF72E 80 scr fill
3 13B4B 13B4B 40A AF72E 80 scr fill
3 13B4C 13B4C 40A AF72E 80 scr fill
3 13B4D 13B4D 40A AF72E 80 scr fill
3 13B4E 13B4E 40A AF72E 80 scr fill
3 13B4F 13B4F 40A AF72E 80 scr fill
3 13B50 13B50 40A AF72E 80 scr fill
3 13B51 13B51 40A AF72E 80 scr fill
3 13B52 13B52 40A AF72E 80 scr fill
3 13B53 13B53 40A AF72E 80 scr fill
3 13B54 13B54 40A AF72E 80 scr fill
P List
log log phy length
3 13B55 13B55 40A AF72E 80 scr fill
3 13B56 13B56 40A AF72E 80 scr fill
3 13B57 13B57 40A AF72E 80 scr fill
3 13B58 13B58 40A AF72E 80 scr fill
3 13B59 13B59 40A AF72E 80 scr fill
3 13B5A 13B5A 40A AF72E 80 scr fill
3 13B5B 13B5B 40A AF72E 80 scr fill
3 13B5C 13B5C 40A AF72E 80 scr fill
3 13B5D 13B5D 40A AF72E 80 scr fill
3 13B5E 13B5E 40A AF72E 80 scr fill
3 13B5F 13B5F 40A AF72E 80 scr fill
3 13B60 13B60 40A AF72E 80 scr fill
3 13B61 13B61 40A AF72E 80 scr fill
3 13B62 13B62 40A AF72E 80 scr fill
3 13B63 13B63 40A AF72E 80 scr fill
3 13B64 13B64 40A AF72E 80 scr fill
3 13B65 13B65 40A AF72E 80 scr fill
3 13B66 13B66 40A AF72E 80 scr fill
3 13B67 13B67 40A AF72E 80 scr fill
3 13B68 13B68 40A AF72E 80 scr fill
3 13B69 13B69 40A AF72E 80 scr fill
3 13B6A 13B6A 40A AF72E 80 scr fill
3 13B6B 13B6B 40A AF72E 80 scr fill
3 13B6C 13B6C 40A AF72E 80 scr fill
3 13B6D 13B6D 40A AF72E 80 scr fill
3 13B6E 13B6E 40A AF72E 80 scr fill
3 13B6F 13B6F 40A AF72E 80 scr fill
3 13B70 13B70 40A AF72E 80 scr fill
3 13B71 13B71 40A AF72E 80 scr fill
3 13B72 13B72 40A AF72E 80 scr fill
3 13B73 13B73 40A AF72E 80 scr fill
P List
log log phy length
3 13B74 13B74 40A AF72F 80 scr fill
3 13B75 13B75 40A AF72F 80 scr fill
3 13B76 13B76 40A AF72F 80 scr fill
3 13B77 13B77 40A AF72F 80 scr fill
2 13E07 13E07 3FD C2FC1 80 scr fill
2 13E08 13E08 3FD C2FC1 80 scr fill
2 13E09 13E09 3FD C2FC1 80 scr fill
3 15AE9 15AE9 3FD 7E386 80 scr fill
3 15AEA 15AEA 3FD 7E386 80 scr fill
3 15AEB 15AEB 3FD 7E386 80 scr fill
2 15DA3 15DA3 413 113DB 80 scr fill
2 15DA4 15DA4 413 113DB 80 scr fill
2 15DA5 15DA5 413 113DB 80 scr fill
2 15DA6 15DA6 413 113DB 80 scr fill
2 15DA7 15DA7 413 113DB 80 scr fill
2 15DA8 15DA8 413 113DB 80 scr fill
2 15DA9 15DA9 413 113DB 80 scr fill
2 15DAA 15DAA 413 113DB 80 scr fill
2 15DAB 15DAB 413 113DB 80 scr fill
2 15DAC 15DAC 413 113DB 80 scr fill
2 15DAD 15DAD 413 113DB 80 scr fill
2 15DAE 15DAE 413 113DB 80 scr fill
2 15DAF 15DAF 413 113DB 80 scr fill
2 15DB0 15DB0 413 113DB 80 scr fill
2 15DB1 15DB1 413 113DC 80 scr fill
2 15DB2 15DB2 413 113DC 80 scr fill
2 15DB3 15DB3 413 113DC 80 scr fill
2 15DB4 15DB4 413 113DC 80 scr fill
2 15DB5 15DB5 413 113DC 80 scr fill
2 15DB6 15DB6 413 113DC 80 scr fill
2 15DB7 15DB7 413 113DC 80 scr fill
P List
log log phy length
2 15DB8 15DB8 413 113DC 80 scr fill
2 15DB9 15DB9 413 113DC 80 scr fill
2 15DBA 15DBA 413 113DC 80 scr fill
2 15DBB 15DBB 413 113DC 80 scr fill
2 15DBC 15DBC 413 113DC 80 scr fill
2 15DBD 15DBD 413 113DC 80 scr fill
2 15DBE 15DBE 413 113DC 80 scr fill
2 15DBF 15DBF 413 113DC 80 scr fill
2 15DC0 15DC0 413 113DC 80 scr fill
2 15DC1 15DC1 413 113DD 80 scr fill
2 15DC2 15DC2 413 113DD 80 scr fill
2 15DC3 15DC3 413 113DD 80 scr fill
2 15DC4 15DC4 413 113DD 80 scr fill
2 15DC5 15DC5 413 113DD 80 scr fill
2 15DC6 15DC6 413 113DD 80 scr fill
2 15DC7 15DC7 413 113DD 80 scr fill
2 15DC8 15DC8 413 113DD 80 scr fill
2 15DC9 15DC9 413 113DD 80 scr fill
2 15DCA 15DCA 413 113DD 80 scr fill
2 15DCB 15DCB 413 113DD 80 scr fill
2 15DCC 15DCC 413 113DD 80 scr fill
2 15DCD 15DCD 413 113DD 80 scr fill
2 15DCE 15DCE 413 113DD 80 scr fill
2 15DCF 15DCF 413 113DD 80 scr fill
2 15DD0 15DD0 413 113DD 80 scr fill
2 15DD1 15DD1 413 113DE 80 scr fill
2 15DD2 15DD2 413 113DE 80 scr fill
2 15DD3 15DD3 413 113DE 80 scr fill
2 15DD4 15DD4 413 113DE 80 scr fill
2 15DD5 15DD5 413 113DE 80 scr fill
2 15DD6 15DD6 413 113DE 80 scr fill
P List
log log phy length
2 15DD7 15DD7 413 113DE 80 scr fill
2 15DD8 15DD8 413 113DE 80 scr fill
2 15DD9 15DD9 413 113DE 80 scr fill
2 15DDA 15DDA 413 113DE 80 scr fill
2 15DDB 15DDB 413 113DE 80 scr fill
2 15DDC 15DDC 413 113DE 80 scr fill
2 15DDD 15DDD 413 113DE 80 scr fill
2 15DDE 15DDE 413 113DE 80 scr fill
2 15DDF 15DDF 413 113DE 80 scr fill
2 15DE0 15DE0 413 113DE 80 scr fill
2 15DE1 15DE1 413 113DF 80 scr fill
2 15DE2 15DE2 413 113DF 80 scr fill
2 15DE3 15DE3 413 113DF 80 scr fill
2 15DE4 15DE4 413 113DF 80 scr fill
2 15DE5 15DE5 413 113DF 80 scr fill
2 15DE6 15DE6 413 113DF 80 scr fill
2 15DE7 15DE7 413 113DF 80 scr fill
2 15DE8 15DE8 413 113DF 80 scr fill
2 15DE9 15DE9 413 113DF 80 scr fill
2 15DEA 15DEA 413 113DF 80 scr fill
2 15DEB 15DEB 413 113DF 80 scr fill
2 15DEC 15DEC 413 113DF 80 scr fill
2 15DED 15DED 413 113DF 80 scr fill
2 15DEE 15DEE 413 113DF 80 scr fill
2 15DEF 15DEF 413 113DF 80 scr fill
2 15DF0 15DF0 413 113DF 80 scr fill
2 15DF1 15DF1 413 113E0 80 scr fill
2 15DF2 15DF2 413 113E0 80 scr fill
2 15DF3 15DF3 413 113E0 80 scr fill
3 16412 16412 3FD A9B56 80 scr fill
3 16413 16413 3FD A9B56 80 scr fill
P List
log log phy length
3 16414 16414 3FD A9B56 80 scr fill
2 16679 16679 3FD BA24A 80 scr fill
2 1667A 1667A 3FD BA24A 80 scr fill
2 1667B 1667B 3FD BA24A 80 scr fill
2 166AC 166AC 3FD 81B56 80 scr fill
2 166AD 166AD 3FD 81B56 80 scr fill
2 166AE 166AE 3FD 81B56 80 scr fill
2 176E4 176E4 3FD 1BF82 80 scr fill
2 176E5 176E5 3FD 1BF82 80 scr fill
2 176E6 176E6 3FD 1BF82 80 scr fill
1 17ECB 17ECB 3FD 4DA46 80 scr fill
1 17ECC 17ECC 3FD 4DA46 80 scr fill
1 17ECD 17ECD 3FD 4DA46 80 scr fill
3 1A776 1A776 3FF 4705C 80 scr fill
3 1A777 1A777 3FF 4705C 80 scr fill
3 1A778 1A778 3FF 4705C 80 scr fill
2 1AB7A 1AB7A 409 41F99 80 scr fill
2 1AB7B 1AB7B 409 41F99 80 scr fill
2 1AB7C 1AB7C 409 41F99 80 scr fill
2 1AB7D 1AB7D 409 41F99 80 scr fill
2 1AB7E 1AB7E 409 41F99 80 scr fill
2 1AB7F 1AB7F 409 41F99 80 scr fill
2 1AB80 1AB80 409 41F99 80 scr fill
2 1AB81 1AB81 409 41F99 80 scr fill
2 1AB82 1AB82 409 41F99 80 scr fill
2 1AB83 1AB83 409 41F99 80 scr fill
2 1AB84 1AB84 409 41F99 80 scr fill
2 1AB85 1AB85 409 41F99 80 scr fill
2 1AB86 1AB86 409 41F99 80 scr fill
2 1AB87 1AB87 409 41F99 80 scr fill
2 1AB88 1AB88 409 41F99 80 scr fill
P List
log log phy length
2 1AB89 1AB89 409 41F99 80 scr fill
2 1AB8A 1AB8A 409 41F99 80 scr fill
2 1AB8B 1AB8B 409 41F99 80 scr fill
2 1AB8C 1AB8C 409 41F99 80 scr fill
2 1AB8D 1AB8D 409 41F99 80 scr fill
2 1AB8E 1AB8E 409 41F99 80 scr fill
2 1AB8F 1AB8F 409 41F99 80 scr fill
2 1AB90 1AB90 409 41F99 80 scr fill
2 1AB91 1AB91 409 41F99 80 scr fill
2 1AB92 1AB92 409 41F99 80 scr fill
2 1AB93 1AB93 409 41F99 80 scr fill
2 1AB94 1AB94 409 41F99 80 scr fill
2 1AB95 1AB95 409 41F99 80 scr fill
2 1AB96 1AB96 409 41F99 80 scr fill
2 1AB97 1AB97 409 41F99 80 scr fill
2 1AB98 1AB98 409 41F99 80 scr fill
2 1AB99 1AB99 409 41F99 80 scr fill
2 1AB9A 1AB9A 409 41F99 80 scr fill
2 1AB9B 1AB9B 409 41F99 80 scr fill
2 1AB9C 1AB9C 409 41F99 80 scr fill
2 1AB9D 1AB9D 409 41F9A 80 scr fill
2 1AB9E 1AB9E 409 41F9A 80 scr fill
2 1AB9F 1AB9F 409 41F9A 80 scr fill
2 1ABA0 1ABA0 409 41F9A 80 scr fill
2 1ABA1 1ABA1 409 41F9A 80 scr fill
2 1ABA2 1ABA2 409 41F9A 80 scr fill
2 1ABA3 1ABA3 409 41F9A 80 scr fill
2 1ABA4 1ABA4 409 41F9A 80 scr fill
2 1ABA5 1ABA5 409 41F9A 80 scr fill
2 1ABA6 1ABA6 409 41F9A 80 scr fill
2 1ABA7 1ABA7 409 41F9A 80 scr fill
P List
log log phy length
2 1ABA8 1ABA8 409 41F9A 80 scr fill
2 1ABA9 1ABA9 409 41F9A 80 scr fill
2 1ABAA 1ABAA 409 41F9A 80 scr fill
2 1ABAB 1ABAB 409 41F9A 80 scr fill
2 1ABAC 1ABAC 409 41F9A 80 scr fill
2 1ABAD 1ABAD 409 41F9A 80 scr fill
2 1ABAE 1ABAE 409 41F9A 80 scr fill
2 1ABAF 1ABAF 409 41F9A 80 scr fill
2 1ABB0 1ABB0 409 41F9A 80 scr fill
2 1ABB1 1ABB1 409 41F9A 80 scr fill
2 1ABB2 1ABB2 409 41F9A 80 scr fill
2 1ABB3 1ABB3 409 41F9A 80 scr fill
2 1ABB4 1ABB4 409 41F9A 80 scr fill
2 1ABB5 1ABB5 409 41F9A 80 scr fill
2 1ABB6 1ABB6 409 41F9A 80 scr fill
2 1ABB7 1ABB7 409 41F9A 80 scr fill
2 1ABB8 1ABB8 409 41F9A 80 scr fill
2 1ABB9 1ABB9 409 41F9A 80 scr fill
2 1ABBA 1ABBA 409 41F9A 80 scr fill
2 1ABBB 1ABBB 409 41F9A 80 scr fill
2 1ABBC 1ABBC 409 41F9A 80 scr fill
2 1ABBD 1ABBD 409 41F9A 80 scr fill
3 1AF52 1AF52 3FE 8FEA1 80 scr fill
3 1AF53 1AF53 3FE 8FEA1 80 scr fill
3 1AF54 1AF54 3FE 8FEA1 80 scr fill
1 1C511 1C373 3FD 3C8FE 80 scr fill
1 1C512 1C374 3FD 3C8FE 80 scr fill
1 1C513 1C375 3FD 3C8FE 80 scr fill
3 1CE02 1CE02 3FD 30C44 80 scr fill
3 1CE03 1CE03 3FD 30C44 80 scr fill
3 1CE04 1CE04 3FD 30C44 80 scr fill
P List
log log phy length
2 1F32F 1F165 3FD 1BAE9 80 scr fill
2 1F330 1F166 3FD 1BAE9 80 scr fill
2 1F331 1F167 3FD 1BAE9 80 scr fill
2 1F57B 1F3B1 3FE 448D9 80 scr fill
2 1F57C 1F3B2 3FE 448D9 80 scr fill
2 1F57D 1F3B3 3FE 448D9 80 scr fill
0 1F97C 1F7A0 3FF 51C9F 80 scr fill
0 1F97D 1F7A1 3FF 51C9E 80 scr fill
0 1F97E 1F7A2 3FF 51C9E 80 scr fill
0 1F97F 1F7A3 3FF 51C9D 80 scr fill
0 1F980 1F7A4 3FF 51C9D 80 scr fill
0 1F981 1F7A5 3FF 51C9C 80 scr fill
0 1F982 1F7A6 3FF 51C9C 80 scr fill
0 1F983 1F7A7 3FF 51C9B 80 scr fill
0 1F984 1F7A8 3FF 51C9B 80 scr fill
0 1F985 1F7A9 3FF 51C9A 80 scr fill
0 1F986 1F7AA 3FF 51C9A 80 scr fill
0 1F987 1F7AB 3FF 51C99 80 scr fill
0 1F988 1F7AC 3FF 51C99 80 scr fill
3 1FE8C 1FCB0 3FD 1D5D2 80 scr fill
3 1FE8D 1FCB1 3FD 1D5D2 80 scr fill
3 1FE8E 1FCB2 3FD 1D5D2 80 scr fill
2 21CE0 21B16 3FD 1C1E0 80 scr fill
2 21CE1 21B17 3FD 1C1E0 80 scr fill
2 21CE2 21B18 3FD 1C1E0 80 scr fill
2 222E4 2211A 3FD 22EF4 80 scr fill
2 222E5 2211B 3FD 22EF4 80 scr fill
2 222E6 2211C 3FD 22EF4 80 scr fill
2 22B3F 22975 3FD 5577B 80 scr fill
2 22B40 22976 3FD 5577B 80 scr fill
2 22B41 22977 3FD 5577B 80 scr fill
P List
log log phy length
Head 0 Entries: 109
Head 1 Entries: 55
Head 2 Entries: 117
Head 3 Entries: 1E7
Total Entries: 45C
PostPosted: December 20th, 2016, 16:56
Ok, V40 shows no entries, so do the following :
m0,6,3,,,,,22
m0,6,2,,,,,22
m0,2,1,,,,,22
m0,2,2,,,,,22
Wait for each of the commands to finish. You can issue the first command, power off/on and check if the drive is properly detected with correct capacity and if you an scan user space. If not move to the 2nd command and test again, and so on.
PostPosted: December 21st, 2016, 9:00
you forget to post head resistance
on Level 7> X
its interesting that on some drives with low head resistance pc3k fail to recover translators automatically.
but surprisingly... Seagate Doctor (Salvation) does recover it with single click... :shock:
PostPosted: March 18th, 2017, 21:35
these automatic translator recovery things should never be started...
check ccc's avatar
No bitcoin donations :)
PostPosted: March 18th, 2017, 21:47
Recover translator can take a very long time. I've had a few run through the weekend before they finished. If all else fails, sometimes it's the only way to restore the translator and get back the data.
Hard Drive & RAID Data Recovery Services
https://www.data-medics.com/raid-data-recovery/
