 Post subject: Toshiba DT01ACA050 Sata 500 GB
PostPosted: March 28th, 2017, 7:51
I have Toshiba 500 GB DT01ACA050 Sata 3.5 inch hdd. In which family hdd will work.
Any help appreciated......
 Post subject: Re: Toshiba DT01ACA050 Sata 500 GB
PostPosted: March 28th, 2017, 8:09
Try this 7210DLE6 family (from Hitachi) may help.
PostPosted: March 28th, 2017, 8:38
hdd failed to detect family.....showing all information correctly.....
PostPosted: March 28th, 2017, 13:59
Definitely ^
Which one is it ?
Or
PostPosted: March 29th, 2017, 1:14
hdd failed to detect family....and in top left corner in toshiba utility showing size, s/n, fw......
PostPosted: March 29th, 2017, 1:21
Oh, it won't be the detected automatically
Choose manually 7210DLE6 from the ARM utility
PostPosted: April 4th, 2017, 6:00
This is only remarked as Toshiba, actually is Hitachi ARM drive.
PostPosted: April 5th, 2017, 13:43
Betty ,
So many times this is discussed on acelab forums ,Please check there
Amarbir S Dhillon
CDRLabs Data Recovery - [ Chandigarh ,India ]
My Data Recovery Experiments - > https://www.facebook.com/chandigarhdatarecovery
PostPosted: April 17th, 2017, 23:54
Try Both Families 7230ALA6 or 7210DLE6 , one of them will work ....
if fail try again with the Tech Keay detection option... :D
www.datarecovery.com.do Recuperaci├▓n de datos Rep├╣blica Dominicana Santo Domingo------
PostPosted: April 18th, 2017, 3:11
The PCB P/N of the DT01ACA050 is 0A90381. A Google search suggests that Hitachi models which use this PCB include HDS721010DLE630 and HDS721050DLE630.
The HDS723030ALA640 uses a PCB P/N 0A90284.
