 Post subject: Need resources for Toshiba ACA - MS1OA7S0
PostPosted: October 9th, 2017, 12:17
Any chance someone has resources for Toshiba DT01ACA050 (Hitachi DLE series) with firmware of MS1OA7S0? I got lots of resources but closest I have to what I need is MS1OA750 but it looks like I need the same version of '7S0'.
Thanks!
 Post subject: Re: Need resources for Toshiba ACA - MS1OA7S0
PostPosted: October 12th, 2017, 3:29
I've checked dont have one sorry Alyn
PostPosted: October 12th, 2017, 3:42
Thanks!
Lucky.. got it
hope it helps
Good luck :wink:
TOSHIBA DT01ACA050-MS1OA750-Z3QG1SDGS_C2670.rar [1.15 MiB]
Downloaded 126 times
PostPosted: October 12th, 2017, 9:34
Judging by the filename it says 750, not 7S0. Is it indeed 7S0?
Northwind Data Recovery - Greece
WD Trusted Partners
PostPosted: October 12th, 2017, 13:26
If there is any question as to whether the "S" version exists ...
https://pastebin.com/yei3tggy
smartctl 6.4 2015-06-04 r4109 [x86_64-linux-3.16.0-4-amd64] (local build)
Copyright (C) 2002-15, Bruce Allen, Christian Franke, http://www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family: Toshiba 3.5" DT01ACA... Desktop HDD
Device Model: TOSHIBA DT01ACA050
Serial Number: 7xxxxxxxS
LU WWN Device Id: 5 000039 ffcd86880
Add. Product Id: DELL(tm)
Firmware Version: MS1OA7S0
User Capacity: 500,107,862,016 bytes [500 GB]
Sector Sizes: 512 bytes logical, 4096 bytes physical
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
PostPosted: October 13th, 2017, 8:28
Thanks for your replies, I appreciate it.
IT is a 'S' and not '5' - I managed to get these resources but they were not especially useful, it turned out heads were defective and after head replacement it became accessible :D
PostPosted: October 13th, 2017, 15:50
Glad it worked out! :-)
www.pcimage.co.uk
PostPosted: October 14th, 2017, 3:21
Good job!
WD Trusted Partners
