 Post subject: Anyone here have a monster CPU and latest release of PC3K?
PostPosted: December 12th, 2017, 18:04
I'm testing the latest version of DE which has a nice compressed image format. In the mostly empty space it seems to have no issue compressing and copying at 120Mb/s, but in the full areas the speed is dropping to more like 50-60Mb/s.
I don't know if this speed drop is just a limitation of the software or if it's related to my sub-par i5 CPU. I do see that it's hitting around 95% utilization but not quite maxing out.
Anyone out there have a monster 10+ core CPU and PC-3000 who can test what speed they get using the compression? I'm just wondering if it's worth upgrading to something like a Ryzen Threadripper to be able to utilize this compression. I'd just hate to drop $2K just to get the same result.
 Post subject: Re: Anyone here have a monster CPU and latest release of PC3
PostPosted: December 12th, 2017, 18:52
What's your PC specs? Exact CPU model, RAM...
ACELab partner
PostPosted: December 12th, 2017, 19:09
To me, the 2GB compressed file chunks it makes are risky if something goes wrong. I won't be using it.
PostPosted: December 12th, 2017, 19:12
My current CPU is i5-4590 running at stock 3.3Ghz. 32Gb of RAM.
Up until now, CPU has never been an issue since data recovery isn't usually very processor intensive. But, trying to compress entire HDDs now is a new trick.
I've had my eye on the Gigabyte X399 Gaming 7 motherboard with 5 full size PCIe slots anyway. I'm really just hoping to justify the cost to myself.
Even if someone with a hyperthreaded i7 can run the test for me and show that it's faster will probably convince me it's worth upgrading.
PostPosted: December 12th, 2017, 19:13
I store everything on a RAID 6 array, so I'm not concerned about things like bad sectors too much. But, yeah, I want to thoroughly test this out before starting to really implement it.
PostPosted: December 12th, 2017, 19:18
Same here, couple RAID-6 units with compression.
PostPosted: December 12th, 2017, 21:06
What sort of compression are you using?
PostPosted: December 13th, 2017, 5:15
Definitely nice. Been keeping my eye on an upgrade, too.
Hard Disk Drive, SSD, USB Drive and RAID Data Recovery Specialist in Massachusetts
PostPosted: December 13th, 2017, 6:05
Synology Btrfs entire array compression.
PostPosted: December 13th, 2017, 19:00
So you're not using direct attached storage then. You running a 10Gbps NIC?
PostPosted: December 14th, 2017, 0:56
PM sent :)
PostPosted: March 19th, 2018, 18:13
Sorry but this is insane. don't you have enough space to store the images? Can't believe this was on their priority list to add compression to DE :roll:
