 Post subject: ST1000LM035-1RK172 BSY
PostPosted: November 20th, 2017, 14:14
Hi
I got ST1000LM035-1RK172 it gets ready and Drive ID is full and correct but the terminal is non stop repeating the last code
and when I do sector edit it get BSY and Stay BSY
and I have no terminal access
here is what terminal shows
Boot 0x80M
QB
Rst 0x80MSrv DETCR init 0x0000
(P) SATA Reset
RAW OFF
PASS
(DOS Table) Worst Count: 00000FF6 At SU: 00004D6F NT: 00000000 OT: 00000110
(POR) Recover Secondary MCMT Opened Recovered
(MC POR Duration): 00000001FC
Intel 6G->3G
Send Status: COMRESET seen
CSpd= 3Gbps
Common path start quit now ProcessRC: 00000000,00000000ReadContinuous: 028D1FCE,00000186TotalEntries:0000   XfrLen:0186UnrecovSectorCount:0000,0000NumUDEs: 00000000,00000000Failed: 40000087Out:
SP Regen FAIL
SPRegen [0000|03110488] @LBA=0x028D1FCE
Setup currentretry count
Hd 1  Err Blk      31797AC  BER pre -1.881127
Out:
Update Mask - 000000001468FE70 - 00000008 - 00
Harden - 028D1FCE
InitiateMarkPendingReallocateRequest for disc_lba: 00028D1FCE CHS: 00012BDD.01.0000
Assert 741D - LBA 028D1FCE!
Common path start quit now ProcessRC: 00000002,00000000ReadContinuous: 028D1FCF,00000185TotalEntries:0000   XfrLen:0185UnrecovSectorCount:0000,0000NumUDEs: 00000000,00000000Failed: 40000087Out:
SP Regen FAIL
SPRegen [0000|03110488] @LBA=0x028D1FCF
Hd 1  Err Blk      31797AD  BER pre -1.880568
Out:
Update Mask - 000000001468FE78 - 00000008 - 00
Harden - 028D1FCF
InitiateMarkPendingReallocateRequest for disc_lba: 00028D1FCF CHS: 00012BDD.01.0001
Assert 741D - LBA 028D1FCF!
Common path start quit now ProcessRC: 00000002,00000000ReadContinuous: 028D1FD0,00000184TotalEntries:0000   XfrLen:0184UnrecovSectorCount:0000,0000NumUDEs: 00000000,00000000Failed: 40000087Out:
SP Regen FAIL
SPRegen [0000|03110488] @LBA=0x028D1FD0
Hd 1  Err Blk      31797AE  BER pre -1.880385
Out:
Update Mask - 000000001468FE80 - 00000008 - 00
Harden - 028D1FD0
InitiateMarkPendingReallocateRequest for disc_lba: 00028D1FD0 CHS: 00012BDD.01.0002
Assert 741D - LBA 028D1FD0!
Common path start quit now ProcessRC: 00000002,00000000ReadContinuous: 028D1FD1,00000309TotalEntries:0000   XfrLen:0309UnrecovSectorCount:0000,0000NumUDEs: 00000000,00000000Failed: 40000087Out:
SP Regen FAIL
SPRegen [0000|03110488] @LBA=0x028D1FD1
Hd 1  Err Blk      31797AF  BER pre -1.881700
Out:
Update Mask - 000000001468FE88 - 00000008 - 00
Harden - 028D1FD1
InitiateMarkPendingReallocateRequest for disc_lba: 00028D1FD1 CHS: 00012BDD.01.0003
Assert 741D - LBA 028D1FD1!
Common path start quit now ProcessRC: 00000002,00000000ReadContinuous: 028D1FD2,00000308TotalEntries:0000   XfrLen:0308UnrecovSectorCount:0000,0000NumUDEs: 00000000,00000000Failed: 40000087Out:
SP Regen FAIL
SPRegen [0000|03110488] @LBA=0x028D1FD2
Hd 1  Err Blk      31797B0  BER pre -1.877858
Out:
Update Mask - 000000001468FE90 - 00000008 - 00
Harden - 028D1FD2
InitiateMarkPendingReallocateRequest for disc_lba: 00028D1FD2 CHS: 00012BDD.01.0004
Assert 741D - LBA 028D1FD2!
Common path start quit now ProcessRC: 00000002,00000000ReadContinuous: 028D1FD3,00000307TotalEntries:0000   XfrLen:0307UnrecovSectorCount:0000,0000NumUDEs: 00000000,00000000Failed: 40000087Out:
SP Regen FAIL
SPRegen [0000|03110488] @LBA=0x028D1FD3
Hd 1  Err Blk      31797B1  BER pre -1.880770
Out:
Update Mask - 000000001468FE98 - 00000008 - 00
Harden - 028D1FD3
InitiateMarkPendingReallocateRequest for disc_lba: 00028D1FD3 CHS: 00012BDD.01.0005
Assert 741D - LBA 028D1FD3!
Common path start quit now ProcessRC: 00000002,00000000ReadContinuous: 028D1FD4,00000306TotalEntries:0000   XfrLen:0306UnrecovSectorCount:0000,0000NumUDEs: 00000000,00000000Failed: 40000087Out:
SP Regen FAIL
SPRegen [0000|03110488] @LBA=0x028D1FD4
Hd 1  Err Blk      31797B2  BER pre -1.880903
Out:
Update Mask - 000000001468FEA0 - 00000008 - 00
Harden - 028D1FD4
InitiateMarkPendingReallocateRequest for disc_lba: 00028D1FD4 CHS: 00012BDD.01.0006
Assert 741D - LBA 028D1FD4!
the last part keep repeating forever
 Post subject: Re: ST1000LM035-1RK172 BSY
PostPosted: November 21st, 2017, 7:50
Pending process + scratch panel updating. You can wait till it finish, but better to use terminal commands in order to switch-off background processes.
PostPosted: November 28th, 2017, 14:36
Not quite sure, but this may help:
To get the terminal and to work with service area read the ROM in Boot Code, then unlock techno-mode, write changes and restart drive. Then unlock the drive prepared by utility and press Ctrl+Z (many times right after unlocking)
And don't forget to save 28!
PostPosted: December 3rd, 2017, 5:34
save 28,35,1B uncheck 93 dont clear SMART its Rosewood.
346 backup as well.
PostPosted: March 11th, 2018, 6:06
Hi to all
I have the same problem
but after read ROM with terminal and apply patch no different and
i don't access to SA
Boot 0x80M
Tech Unlock Handshake: 0xB7824A6D
Reply:
QB
(P) SATA Reset
RAW OFF
PASS
(DOS Table) Worst Count: 00000000 At SU: FFFFFFFF NT: 00000000 OT: 00000000
(MC POR Duration): 0000000147
Intel 6G->3G
CSpd= 3Gbps
Common path start quit now ProcessRC: 00000000,00000000ReadContinuous: 00E799B4,00000180TotalEntries:0000 XfrLen:0180UnrecovSectorCount:0000,0000NumUDEs: 00000000,00000000Failed: 40000087Out:
SP Regen FAIL
SPRegen [0000|03110488] @LBA=0x00E799B4
Hd 0 Err Blk 198E89A BER pre -1.956027
Out:
Update Mask - 00000000073CCDA0 - 00000008 - 00
Harden - 00E799B4
InitiateMarkPendingReallocateRequest for disc_lba: 0000E799B4 CHS: 00009AEE.00.0000
Assert 741D - LBA 00E799B4!
Common path start quit now ProcessRC: 00000002,00000000ReadContinuous: 00E799B5,0000017FTotalEntries:0000 XfrLen:017FUnrecovSectorCount:0000,0000NumUDEs: 00000000,00000000Failed: 40000087Out:
SP Regen FAIL
SPRegen [0000|03110488] @LBA=0x00E799B5
and repeated "Common path start quit now ProcessRC"
Are you have any idea ?
NS DATA RECOVERY
www.nsrecovery.ir
PostPosted: March 12th, 2018, 6:23
This Issue can be solved editing drive config.
With PC3000 you can edit drive parameters.
if you dont have PC3K from a term session check those useful commands ( they really work ! )
https://www.data-medics.com/forum/seaga ... -t901.html
PostPosted: March 17th, 2018, 4:13
hi
unfortunately , I don't have access to sysfiles for backup important modules and edit HDD id
NS DATA RECOVERY
www.nsrecovery.ir
PostPosted: March 17th, 2018, 9:04
hamidbid wrote:
hi
do you have terminal access ?
what do you mean you don't have access to sysfiles ? what tools you are using ?
Data Recovery Pakistan
PostPosted: March 18th, 2018, 6:10
MindMergepk wrote:
hamidbid wrote:
hi
pc3000 udma
and i recoved this models minimum 15 time , but this times its different
and after read ROM and apply patch restart the utility i dont have access to sa
described in below link
http://blog.acelaboratory.com/pc-3000-f ... rives.html
NS DATA RECOVERY
www.nsrecovery.ir
PostPosted: March 18th, 2018, 8:52
can check remotely, PM me if interested.
PostPosted: July 19th, 2018, 22:20
use virtual start, it might work.
PostPosted: October 14th, 2018, 14:07
Banned User
Own a Dell 7779, by far the worst laptop I have ever owned in my life. 100% disk usage, hasn't worked right since the day I bought it, I have a 100% Walmart tablet windows 10 laptop that runs faster then this Dell I paid over $1100 for.
Users browsing this forum: No registered users and 29 guests
