 Post subject: WD20EARX-00PASB0
PostPosted: March 19th, 2018, 18:04
Hello All,
I have been working on this drive for a few days now and I seem to be getting nowhere. I have full access to the SA and can read and write modules perfectly. However, there is no logical access at all. All attempts to read a sector result in ERR/ABR errors. There was some SA modules that had errors on them which were repaired and the SA checks as good. I manually verified the content on all the modules required for logical access.
My assumption is that the PCB is bad but that does not seem to jive with being able to access and r/w the SA.
I tried translator regeneration and still have the same issue.
I am not sure what to try next other than PCB swap and HOT Swap. I am waiting on the donor now.
Any ideas?
 Post subject: Re: WD20EARX-00PASB0
PostPosted: March 19th, 2018, 22:41
Is this with or without head swap?
Hard Disk Drive, SSD, USB Drive and RAID Data Recovery Specialist in Massachusetts
PostPosted: March 19th, 2018, 23:29
Without. No changes have been made to the internals.
PostPosted: March 20th, 2018, 3:25
Likely translator is not loading correctly.
Initializing the drive off of one of the system heads only will help.
PostPosted: March 20th, 2018, 13:35
Altering the head map to only head 0 or 1 does not fix the issue. I tried regenerating the translator and also nothing.
I did a module 03 recovery and got
Module 03 recovery
Format data reading..................... : Ok
FMT TPI set error Device Error Detected: "VSC ERR W R GAP INFO NOT AVAILABLE"
Which is interesting.
PostPosted: March 20th, 2018, 13:36
I tried a module 3 recovery and got this....
Module 03 recovery
PostPosted: March 20th, 2018, 13:37
Sounds like heads could be bad then. Is it out of an external drive? And what did the customer say may have led to failure?
PostPosted: March 20th, 2018, 13:38
Yes, out of a my book external that was sitting on a desk.
PostPosted: March 20th, 2018, 13:42
And the customer has no idea at all, right? No drops, no signs of freezing or random disconnects or inability to browse, etc, right? Facepalm.
SMART looks clean?
PostPosted: March 20th, 2018, 16:00
Smart looks clean. What really gets me is that the W R head distance means it cannot read the microjogs? or some other adaptive setting? That is what has me confused
PostPosted: March 20th, 2018, 16:04
Have you run a heads test?
PostPosted: March 20th, 2018, 16:40
does it detected with full ID ?
or you are accessing SA only when you block the SA access ?
Data Recovery Pakistan
PostPosted: March 20th, 2018, 16:55
It detects with full ID. No issues there. I read and wrote to the SA on both head 0 and head 1 with no issues.
PostPosted: March 20th, 2018, 17:00
What about the other heads? Translator will not initialise properly if a suspect head is detected.
PostPosted: March 20th, 2018, 17:07
Heads test
Cylinder to test........................ : -10
Heads to test........................... : 0,1,2,5,6,7
Test every head......................... : no more then 1 min.
Head 0.................................. : Ok
Head 1.................................. : Ok
Head 2.................................. : Ok
Head 5.................................. : Ok
Head 6.................................. : Ok
Head 7.................................. : Ok
PostPosted: March 20th, 2018, 17:14
Fair enough.
Did you try the “slow responding fix” ?
PostPosted: March 20th, 2018, 17:41
Yes I did, nothing as well.
PostPosted: March 21st, 2018, 15:53
Has it been to another data recovery company? Hope it was not sabotaged or something.
PostPosted: March 21st, 2018, 15:57
As far as I can tell it has not been opened aside from myself. Its just strange, very strange.
PostPosted: March 21st, 2018, 16:14
Could be that some scumbag has done something to it, like writing non-native 4x adaptives to it or something?
Worth asking if it has been to another DR company and their quote declined?
Users browsing this forum: No registered users and 45 guests
