 Post subject: ST3000DM001 Capacity: 3.6 gb. it blocks DRD DSC and ERR ABR
PostPosted: June 21st, 2018, 12:53
Hello I have a hard drive of my client. In PC-3000 it shows the model, SN, FW but Capacity: 3.6 gb. it blocks DRD DSC and ERR ABR
I thought there is Head's problem
HDD out of service
ST3000DM001
S / N: W1F28494
PN: 1CH166-505
FW: CC44
Date: 13296
Site Code: WU
PreampType: B4 03
Donor hard drive
ST3000DM001
S / N: W1F2QVR5
PN: 1CH166-302
FW: CC26
Date: 13377
Site Code: WU
PreampType: CC 06
I tried changing Head Donor but it's the same problem: It shows the model, SN, FW but Capacity: 3.6 gb. it blocks DRD DSC and ERR ABR
I searched the hard drive with PreampType: B4 03 on the site donordrives.com, harddrivesforsale.com, ebay but it is not diposible.
My question:
if the head is not compatible, he can not find the model ?
you can use another hard disk with other PreampType that compatible with the hard disk PreampType: B4 03 ?
Thanks in advance
Cordailement
Sorry from my English
 Post subject: Re: ST3000DM001 Capacity: 3.6 gb. it blocks DRD DSC and ERR
PostPosted: June 21st, 2018, 13:28
Just to be sure, did you try the patient head in the donor hdd ? What were the results ?
PostPosted: June 21st, 2018, 14:45
hvd wrote:
My question:
Correct, if the preamp is not compatible, then it cannot read the firmware, which contains the drive model.
Need at least B4 more than likely.
Hard Disk Drive, SSD, USB Drive and RAID Data Recovery Specialist in Massachusetts
PostPosted: June 22nd, 2018, 2:58
Hello
Head 4 broke well (see photo).
It is possible to disable the Head 4 to read other head.
Thank
PostPosted: June 22nd, 2018, 2:59
labtech wrote:
hvd wrote:
My question:
Hello
Thanks for your information
Users browsing this forum: No registered users and 6 guests
