 Post subject: need toshiba 2tb room
PostPosted: August 15th, 2018, 9:25
need toshiba 2tb rom
hdd cam without pcb
https://www.facebook.com/datarecoveryegypt
 Post subject: Re: need toshiba 2tb room
PostPosted: August 15th, 2018, 9:52
nice idea
islamm3rouf wrote:
hdd cam without pcb
good luck
BTW IMHO you shouldn't take others drives and mess with it
PostPosted: August 15th, 2018, 14:42
What jermy is trying to say is that without the original PCB there's absolutely no possibility to recover the data.
The fact that you don't know that shows that you're unqualified to be offering data recovery services.
PostPosted: August 16th, 2018, 7:30
i test other same pcb with soft
it spin without clicking and sound seems good
but identify with the donor sn
so i was thinking if we found donor soft it will rise again
PostPosted: August 26th, 2018, 18:07
Already answered you. Without original ROM no recovery is possible.
http://www.pclab.com.pt facebook.com/PCLAB.Assistencia.Tecnica
ACELab partner
PostPosted: August 26th, 2018, 21:05
Does anyone know why? Which CPs are mandatory and what do they do?
FWIW, I have analysed the structure of various Toshiba CPs here:
Analysis of Toshiba CPs:
http://www.hddoracle.com/viewtopic.php?f=59&t=2044
PostPosted: August 27th, 2018, 13:21
Because all the CPs except basically the G-List and S.M.A.R.T. are stored in the ROM chip. There's very little on the platters for a service area at all.
While it might be theoretically possible to rebuild the translator, p-list, etc. from scratch it's not practical in the real world. Maybe if deepest Russian secrets were stored on a drive it'd be worth the crazy amount of manual effort, but not for a typical case.
PostPosted: August 27th, 2018, 15:14
I understand where the CPs are stored, I just don't understand what they do. In fact some Toshiba models do have copies of some ROM based CPs in the SA, although you would need to reach the SA to make use of them. Catch 22.
If I were investigating this issue, I would "disturb" a particular CP and observe the sensitivity to these disturbances. That is, I would vary a particular CP parameter in both directions and determine the range over which the drive remains stable.
PostPosted: September 29th, 2018, 20:58
I do have several drives that i don't care about .... as a matter of fact i do have many toshibas with bad blocks that i will not be able to refurb and re-sell so i will end up with PCB only.
I think that i can do some testing when i do have some extra time.
I do have to catch up with my forum and all of the un-read messages because i was away for a while and only started to read the un-readed messages on data recovery forums today.
I have been busy setting up a small business (not data recocvery related) and i did spend some time on it so i ended up with data recovery matters to explore pilling up along side with forum messages to read and reply.
What i can do is to pick up a Toshiba drive that is way to damage to refurb like with many bad blocks caused by dying heads and start replacing CPs one by one with donnor CPs to see what CPs can't be replaced by others of another drive of teh same model/family.
This should show at least what CPs on ROM are unique and required for LBA data access....
But of course there would be limitations as this "method" would target CPs that can be addressed by VSC to read CPs and without a full ROM dump we would be able to investigate if there are "hidden" or CPs not addressed by read/write VSC to access CP ...
I would have to take a full ROM dump (easy to do) and check that out as well ...
Many possibilities to investigate but by now there are very clever people that can rebuild ARM HGST ROM/NVRAM and Seagate F3 ROM so if it were to be possible/easy to rebuild TOSHIBA ROM by now i think at least one guy or 2 should have discovered a viable method to do so ...
