 Post subject: ST3000DM001 Will not allow access to the entire drive
PostPosted: September 24th, 2018, 9:07
I have a Seagate 3TB model number: ST3000DM001, initially the drive has got Head 1 faulty, i have tried to read the rest of the heads but the drive is reaching the ready state after a long while. I have completed the translator regeneration which made the drive reach the ready state must faster, the drive started imaging successfully all heads apart from head 1, at 47% of the imaging process all heads stopped reading. New read/write heads have been transplanted but i am still having the same issue it will read no sectors at all after the 47%.
I have also tried to rewrite the system files again but with no joy.
Could anyone help please.
 Post subject: Re: ST3000DM001 Will not allow access to the entire drive
PostPosted: September 24th, 2018, 12:01
Users with little experience come here and criticize experienced users who suggest to consult a professional. It is because of cases like this .
From what you said, it probably did not need translator regeneration. One failed or failing head would result in lots of read errors causing all sorts of defect lists to overflow and cause poor operation.
Translator on this model is based on more than one defect list. Translator regeneration only takes into account one list. This means new translator does not include all required defects and without these there will result in 'shifts' between relative and actual position of logical sectors. these shifts will cause errors and prevent surface access.
Replacement of heads would have only further complicated the issue.
With the poor condition of the device, in addition to this new translator error, it really is time to consult someone who can help. Repeated attempts to work on this with no real ideas of what is needed or how to correctly execute it will simply harm the user data and limit its recoverable condition.
PostPosted: September 24th, 2018, 12:02
can we see the full terminal log ?
could be initial problem with Media Cache
Data Recovery Pakistan
PostPosted: September 24th, 2018, 13:54
Please fins the terminal log requierd
PostPosted: September 26th, 2018, 10:20
Many thanks to MindMergepk. You gave us a great help and the problem is now resolved, we are able to read the whole drive with no issues. Many thanks again for your help and support.
PostPosted: September 26th, 2018, 10:32
you are welcome :D
PostPosted: February 15th, 2019, 15:08
So how ?
A Recovery Service In Turkey . Veri Kurtarma Türkiye https://www.digitalverikurtarma.com
Donor Drives hdddonormarket.com
PostPosted: February 16th, 2019, 2:18
HddDonorMarket wrote:
So how ?
what's your problem ?
NS DATA RECOVERY
www.nsrecovery.ir
PostPosted: July 20th, 2022, 20:06
What a useless thread :lol:
PostPosted: July 21st, 2022, 1:34
what a useless post :P
PostPosted: July 21st, 2022, 1:42
MindMergepk wrote:
you are welcome :D
W Bhai ,
PM me what you did in this case .
