 Post subject: Loader WD10SDZW-11UMGS0
PostPosted: February 11th, 2020, 11:31
Does anyone have the loader for a Palmer?
WD10SDZW-11UMGS0
ROM Modules:
ROM version............................. : 01.26N
ROM F/W version......................... : 00010026
Overlay F/W version..................... : 01.26N
Servo F/W version....................... : 01.2U
Thank you!
 Post subject: Re: Loader WD10SDZW-11UMGS0
PostPosted: February 11th, 2020, 20:31
Hello Tamas,
i still don't have it, but welcome to the forum!
... and feel free to contact me if you run into pitfalls like building head map for it :)
No bitcoin donations :)
PostPosted: February 12th, 2020, 3:32
Thanks Pepe! I'll contact for you!
PostPosted: February 19th, 2020, 14:06
Also searching for a WD10SMZW-11Y0TS0
Techno mode key
Techno mode key......................... : Ok
RAM:
SA HDD has unknown capacity. SA CHS access may operates wrongly
HDD Info reading........................ : Ok
Heads number............................ : 2
Cyl Count............................... : 512
ROM:
Read ROM................................ : Ok
ROM Data size........................... : 1024 Kb
Flash ROM dir reading................... : Ok (Active)
Flash ROM dir reading (Ext)............. : Ok
Modules directory address............... : 159 117
Module 02 access........................ : Granted
SA Translator loading................... : Ok
SA defects assigned..................... : 2
ROM Modules:
Heads configuration..................... : by map
Heads number in use..................... : 2
Switched off heads...................... : No
Heads map............................... : 0,1
http://www.pclab.com.pt facebook.com/PCLAB.Assistencia.Tecnica
ACELab partner
PostPosted: February 20th, 2020, 12:25
i am hoping to get resources from Tamas' drive soon. I will get back with the resutls...
PostPosted: February 21st, 2020, 7:14
Thanks Pepe.
ACELab partner
PostPosted: March 3rd, 2020, 11:14
Here you go, i hope it helps.
01.26.zip [767.85 KiB]
Downloaded 129 times
PostPosted: March 3rd, 2020, 13:59
pepe, can you plz check LDR for this also ?
ROM Modules:
ROM version............................. : 02.1AP
ROM F/W version......................... : 0002000J
Overlay F/W version..................... : 02.1AP
Servo F/W version....................... : 01.3C
Data Recovery Pakistan
PostPosted: March 3rd, 2020, 17:52
Thank You
Will test it tomorrow.
ACELab partner
