 Post subject: WD2.5 COM Port Issue
PostPosted: June 24th, 2020, 6:16
Good day,
I've been using this WD2.5 Com port to read ROM info from WD USB drive for years, and noticed the following error message since a couple of days ago.
HDD Initialization...
Check if COM-port selected correctly and port connection
HDD Initialization...................... : Error
Has anyone encountered this problem before?
 Post subject: Re: WD2.5 COM Port Issue
PostPosted: June 24th, 2020, 10:21
Are you using Acelab serial adapters or some 3rd party? The error might be related to that. I have also noticed they lifted the communication speed to higher rates and it is hardcoded which i told them it would be good to make configurable.
No bitcoin donations :)
PostPosted: June 28th, 2020, 22:09
Hi Pepe,
I'm using Acelab serial adapters.
Thanks.
PostPosted: June 30th, 2020, 17:48
Does the terminal adapter work with other brands?
