Post new topic Reply to topic  [ 25 posts ]  Go to page Previous  1, 2
 Post subject: Re: ST4000NM0035
PostPosted: August 26th, 2021, 17:19
Hm, i thought he used a TN03 rom and copied adapts in there.
It will probably work this way...
No bitcoin donations :)
PostPosted: August 27th, 2021, 2:08
pepe wrote:
i doubt it would do any good, as the CFW is not compatible with the OVLs in the SA.
Did you check it?
AIUI, this firmware keeps a backup copy in a container. The ROM has two "csiD" containers -- one has the original TN03 firmware components while the other has TN05. @E123 has merely reverted to the original container.
It works, i test it...
can i find the way to made the rest of pcs. same as this one?
Thank you @E123 for helping and you guys for your time to reply to me.
G-House Electronics
PostPosted: August 27th, 2021, 2:59
I know what to do, but perhaps you should compensate @E123 for his time. I believe he normally charges a very small sum for Seagate firmware modifications.
PostPosted: August 27th, 2021, 3:53
i will try to do all what i can , hope to can i do it all
G-House Electronics
PostPosted: August 31st, 2021, 6:28
UPDATE
Thank you @E123 and @fzabkar for your time, i succed also to handle the fully and permanent unlocking on those and reverted to TN05 fw completly unlocked.
G-House Electronics
