Discussions related to PC-3000
Please no pirated software here!
Toshiba old drive (SATA) with G-List corruption
August 14th, 2022, 10:53
Hi All,
Long time since I got such drive.
Model : TOSHIBA MK3261GSYN
Firmware : MH000C9
Capacity : 320 GB (625 142 448)
The drive give full ID, read all its CP but have a damge in its G-List.
I tried to create virtual translator with Data Extractor - didn't help.
Is there a way to fix the drive with the utility?
I tried to erase the G-List but the action didn't succeed to erase it - got error instead.
Can anyone give any tip or direct me?
When tring to create virtual translator with the utility I get the following errors:
Techno ON............................... : Ok
LBA (1 431 985 085) to CHS conversion error:; Device Error Detected 51/21 (AMN;<bit5>)
LBA (1 218 373 799) to CHS conversion error:; Device Error Detected 51/21 (AMN;<bit5>)
LBA (719 813 164) to CHS conversion error:; Device Error Detected 51/21 (AMN;<bit5>)
LBA (762 199 078) to CHS conversion error:; Device Error Detected 51/21 (AMN;<bit5>)
LBA (1 592 144 163) to CHS conversion error:; Device Error Detected 51/21 (AMN;<bit5>)
LBA (1 844 026 267) to CHS conversion error:; Device Error Detected 51/21 (AMN;<bit5>)
LBA (1 651 970 801) to CHS conversion error:; Device Error Detected 51/21 (AMN;<bit5>)
LBA (870 205 334) to CHS conversion error:; Device Error Detected 51/21 (AMN;<bit5>)
LBA (678 585 539) to CHS conversion error:; Device Error Detected 51/21 (AMN;<bit5>)
LBA (1 598 086 929) to CHS conversion error:; Device Error Detected 51/21 (AMN;<bit5>)
LBA (1 490 496 421) to CHS conversion error:; Device Error Detected 51/21 (AMN;<bit5>)
LBA (1 428 661 880) to CHS conversion error:; Device Error Detected 51/21 (AMN;<bit5>)
LBA (937 820 041) to CHS conversion error:; Device Error Detected 51/21 (AMN;<bit5>)
LBA (1 474 653 937) to CHS conversion error:; Device Error Detected 51/21 (AMN;<bit5>)
LBA (1 353 538 979) to CHS conversion error:; Device Error Detected 51/21 (AMN;<bit5>)
LBA (2 034 609 521) to CHS conversion error:; Device Error Detected 51/21 (AMN;<bit5>)
LBA (666 985 622) to CHS conversion error:; Device Error Detected 51/21 (AMN;<bit5>)
LBA (1 405 515 235) to CHS conversion error:; Device Error Detected 51/21 (AMN;<bit5>)
LBA (1 182 720 644) to CHS conversion error:; Device Error Detected 51/21 (AMN;<bit5>)
LBA (1 846 357 352) to CHS conversion error:; Device Error Detected 51/21 (AMN;<bit5>)
LBA (1 164 184 343) to CHS conversion error:; Device Error Detected 51/21 (AMN;<bit5>)
LBA (1 011 115 497) to CHS conversion error:; Device Error Detected 51/21 (AMN;<bit5>)
LBA (937 766 713) to CHS conversion error:; Device Error Detected 51/21 (AMN;<bit5>)
LBA (1 136 502 119) to CHS conversion error:; Device Error Detected 51/21 (AMN;<bit5>)
LBA (1 122 522 955) to CHS conversion error:; Device Error Detected 51/21 (AMN;<bit5>)
LBA (1 227 050 936) to CHS conversion error:; Device Error Detected 51/21 (AMN;<bit5>)
LBA (1 687 322 554) to CHS conversion error:; Device Error Detected 51/21 (AMN;<bit5>)
Best Regards,
Re: Toshiba old drive (SATA) with G-List corruption
August 14th, 2022, 13:31
All those LBAs far exceed the capacity of the drive. :-?
Would you mind uploading the Glist?
August 14th, 2022, 14:54
fzabkar wrote:All those LBAs far exceed the capacity of the drive. :-?
Hi :)
I can't get access to the G-List
See the print screen
https://ibb.co/7rpRjgz
August 14th, 2022, 15:13
Can you dump the SA (read service tracks)?
When PC3K builds a virtual translator, I suppose that it would try to use both the P-list and G-list, and the zone table CP in the ROM. Is the P-list (CP 0xDD) OK?
August 14th, 2022, 16:34
Try reading with the utility it gives you an option to use pba and bypass the damaged glist I think.
Does the drive come ready? I've used hddsuperclone successfully on low capacity tosh's which refused to play nicely with pc3k.
August 14th, 2022, 22:03
fzabkar wrote:Can you dump the SA (read service tracks)?
I can read the P-List but when trieng to build virtual translator I got many errors and can't reach the data even with reading with the utility mode.
Lardman wrote:Try reading with the utility it gives you an option to use pba and bypass the damaged glist I think.
Yes, the drive come ready.
I tried with and without PBA didn't get data/sectors access.
Any Ideas?
August 14th, 2022, 22:38
This LBA corresponds to a capacity of 1TB. It seems to me that, if you can determine why PC3K is attempting to build a virtual translator with this ridiculous LBA, then you will be closer to finding a solution.
August 15th, 2022, 11:19
Thank you all
I gave the drive back without solve it.
August 18th, 2022, 10:36
Is the G-List in this drive actually supported by your version of PC3K?
