 Post subject: WD5000LMVW SED DRIVE LOCKED
PostPosted: July 5th, 2016, 10:25
Hi gurus,
anyone know how to fix a SED DRIVE LOCKED DRIVE ?
Thanks to everyone
 Post subject: Re: WD5000LMVW SED DRIVE LOCKED
PostPosted: July 5th, 2016, 10:41
PC3000 can do it if you have a recent version.
http://forum.acelaboratory.com/viewtopi ... 155&t=8555
PostPosted: July 5th, 2016, 11:37
Thanks for this quick reply, anyway i have some problem with Load DIR in RAM, this phase fails:
Techno mode key
Techno mode key......................... : Ok
RAM:
HDD Info reading........................ : Ok
Heads number............................ : 2
Cyl Count............................... : 256
ROM:
Read ROM................................ : Ok
ROM Data size........................... : 256 Kb
Flash ROM dir reading................... : Ok (Active)
Flash ROM dir reading (Ext)............. : Ok
Modules directory address............... : 62 577
SA regions address...................... : shifted
SA Translator loading................... : Ok
ROM Modules:
ROM version............................. : 02.4CN
ROM F/W version......................... : 0002004C
Overlay F/W version..................... : 02.4CN
Servo F/W version....................... : 02.10
Heads number in use..................... : 2
Switched off heads...................... : No
Heads map............................... : 0,1
Module (0001) read error Module ID 01 reading error Data request error - Device Error Detected: "Unknown error code: 51AD"
This drive reads some sectors but this is very slow and do many badsectors on reading, i cannot do the headmap because the utility show this SED error in RAM.
Any ideas?
PostPosted: July 5th, 2016, 12:01
I don't know how, but suddenly works, i can't figure why...
anyway thank you pcimage!!!
