 Post subject: Seagate does not accept any command in the terminal.
PostPosted: August 3rd, 2016, 3:31
HI
I have a Seagate remembered to turn on this text in the terminal do not have any other access
You help me
Boot 0x40M
Spin Up[0x000246DF]
Trans.
Rst 0x40M
MC Internal LPC Process
Spin Up
(P) SATA Reset
MediaPartition:
Host LBA Length Disc LBA Length Start Cyl Head
Media Partition 00000000 00999DC8 00000000 001333B9 00000000 00000000
MC 00000000 009897F0 00000000 001312FE 00000000 00000000
MSP 009914A0 00000C78 00132294 0000018F 00000210 00000005
User Partition 00999DC8 001333B9 00000205 00000005
MCMainPOR: Start:
Check MCMT Version: Current
MCMainPOR: Non-Init Case
MC Seg Disc and Cache Nodes: 40134924 40132A34
Seg Write Preamble VBM start: 000011B2 end: 000011D9
Footer - start: 000011DB end: 00001202
Seg Read Preamble VBM - start: 00001204 end: 0000122B
Footer - start: 0000122D end: 00001254
Reconstruction: MCMT Reconstruction Start
Max number of MC segments 22E0
Nonvolatile MCMT sequence number 0004166D
[RSRS] 1BF5 DiscLba 000F49FC RW_RTL FFFFFFFF
ProcessRWError -Read- at LBA 000F4A05 Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 000F4A05!
Reconstruction: EXCEPTION: Seg Read Fail: Status = 0000
Continuing after error
ReadFooters (Forward): Segment 1BF5 StartLBA 007A4FE0 Starting Footer LBA 007A5008
SeqNum 0004166E TotalUserBlocks 0000 DiscLba 000F4A01 RW_RTL FFFFFFFF
Footer Status = 0000 DiscLba 000F4A06 RW_RTL FFFFFFFF
Footer Status = 0001 DiscLba 000F4A0B RW_RTL FFFFFFFF
Footer Status = 0001 DiscLba 000F4A10 RW_RTL FFFFFFFF
Footer Status = 0001 DiscLba 000F4A15 RW_RTL FFFFFFFF
Footer Status = 0001 DiscLba 000F4A1A RW_RTL FFFFFFFF
Footer Status = 0001 DiscLba 000F4A1F RW_RTL FFFFFFFF
Footer Status = 0001 DiscLba 000F4A24 RW_RTL FFFFFFFF
Footer Status = 0001 DiscLba 000F4A29 RW_RTL FFFFFFFF
Footer Status = 0001 DiscLba 000F4A2E RW_RTL FFFFFFFF
Footer Status = 0001 DiscLba 000F4A33 RW_RTL FFFFFFFF
Footer Status = 0001 DiscLba 000F4A38 RW_RTL FFFFFFFF
Footer Status = 0001 DiscLba 000F4A3D RW_RTL FFFFFFFF
Footer Status = 0001 DiscLba 000F4A42 RW_RTL FFFFFFFF
Footer Status = 0001 DiscLba 000F4A47 RW_RTL FFFFFFFF
Footer Status = 0001 DiscLba 000F4A4C RW_RTL FFFFFFFF
Footer Status = 0001 DiscLba 000F4A51 RW_RTL FFFFFFFF
Footer Status = 0001 DiscLba 000F4A56 RW_RTL FFFFFFFF
Footer Status = 0001 DiscLba 000F4A5B RW_RTL FFFFFFFF
Footer Status = 0001 DiscLba 000F4A60 RW_RTL FFFFFFFF
Footer Status = 0001 DiscLba 000F4A65 RW_RTL FFFFFFFF
Footer Status = 0001 DiscLba 000F4A6A RW_RTL FFFFFFFF
Footer Status = 0001 DiscLba 000F4A6F RW_RTL FFFFFFFF
Footer Status = 0001 DiscLba 000F4A74 RW_RTL FFFFFFFF
Footer Status = 0001 DiscLba 000F4A79 RW_RTL FFFFFFFF
Footer Status = 0001 DiscLba 000F4A7E RW_RTL FFFFFFFF
Footer Status = 0001 DiscLba 000F4A83 RW_RTL FFFFFFFF
Reconstruction: EXCEPTION: Segment Overall Sequence Number Mismatch, No Valid Footer 0004166E FFFFFFF3
Reconstruction: ProcessIncompletelyWrittenSegment
