 Post subject: ----HELP!!!----- *****Virtual Machines Deleted...******
PostPosted: September 3rd, 2016, 18:58
I hope you are doing great.
I have this HDD where the Virtual Machines were deleted from "VirtualBox" Software. Customer had two HDD as mirror looks like.
I have used R-STUDIO to find the deleted files, I have found some some but not what customer is looking for (files before the day he deleted them).
Is there any way to recover/ find this kind of files with any other way o any way to re build the virtual machine using other files?
Thank you for the help.
Best regards,
 Post subject: Re: ----HELP!!!----- *****Virtual Machines Deleted...******
PostPosted: September 5th, 2016, 1:17
I never had an such experience, but if i were you, then on the clean HDD i would create a virtual machine by using the same software that client uses. Then i would resaerch file structure type of that VM. after that i would try to build a file structure GREP search on client's HDD.
