Toshiba DT01ACA050 Sata 500 GB
http://forum.hddguru.com/viewtopic.php?f=11&t=35195
Author:  crystalrajasthan [ March 28th, 2017, 7:51 ]
Post subject:  Toshiba DT01ACA050 Sata 500 GB
I have Toshiba 500 GB DT01ACA050 Sata 3.5 inch hdd. In which family hdd will work.
Any help appreciated......
Author:  hyuce [ March 28th, 2017, 8:09 ]
Post subject:  Re: Toshiba DT01ACA050 Sata 500 GB
Try this 7210DLE6 family (from Hitachi) may help.
Author:  crystalrajasthan [ March 28th, 2017, 8:38 ]
hdd failed to detect family.....showing all information correctly.....
Author:  jermy [ March 28th, 2017, 13:59 ]
Definitely ^
Which one is it ?
Or
Author:  crystalrajasthan [ March 29th, 2017, 1:14 ]
hdd failed to detect family....and in top left corner in toshiba utility showing size, s/n, fw......
Author:  jermy [ March 29th, 2017, 1:21 ]
Oh, it won't be the detected automatically
Choose manually 7210DLE6 from the ARM utility
Author:  michael chiklis [ April 4th, 2017, 6:00 ]
This is only remarked as Toshiba, actually is Hitachi ARM drive.
Author:  Amarbir[CDR-Labs] [ April 5th, 2017, 13:43 ]
Betty ,
So many times this is discussed on acelab forums ,Please check there
Author:  cocoricamo [ April 17th, 2017, 23:54 ]
Try Both Families 7230ALA6 or 7210DLE6 , one of them will work ....
if fail try again with the Tech Keay detection option... :D
Author:  fzabkar [ April 18th, 2017, 3:11 ]
The PCB P/N of the DT01ACA050 is 0A90381. A Google search suggests that Hitachi models which use this PCB include HDS721010DLE630 and HDS721050DLE630.
The HDS723030ALA640 uses a PCB P/N 0A90284.
