 Post subject: ST500LT012 - LED:000000BC FAddr:00007A43 stuck on bsy
PostPosted: April 29th, 2017, 10:41
I have ST500LT012 the drive spin for few second then stop and the head is moving (not stuck). then it gets DRD DSC.
but when I try to read ID i stuck on BSY DRD DSC until I power OFF/ON the hdd.
and when I start utilities this is what I get:
and after repowering I get in the terminal:
Rst 0x10M
SPINUP FAILED
ExecuteSpinRequest
op=0100 resp=0007
op=0100 resp=0007
CfwDiscCode Not Loaded: 0002B4E0
 Post subject: Re: ST500LT012 - LED:000000BC FAddr:00007A43 stuck on bsy
PostPosted: April 29th, 2017, 12:51
Overlay wasn't loaded. Probably, due to some damages in SA.
PostPosted: April 30th, 2017, 9:46
I suspect bad media but I'm curious why the "SPINUP FAILED" message. The drive spins up fine with HDA isolated, so it's not seized spindle.
PostPosted: April 30th, 2017, 10:26
Because this massage relates to servo recalibration, not to SPIN UP literally. And yes, you have to think about heads replacement, current heads are not good with big probability.
