 Post subject: Need Mod 11 : Fblite family
PostPosted: June 19th, 2017, 12:41
anyone can share the Mod: 11 for the below ROM from a Fblite Family:
ROM Modules:
ROM version............................. : 16.7CG
ROM F/W version......................... : 0016007C
Overlay F/W version..................... : 16.7CG
Servo F/W version....................... : N0.41
Heads number............................ : 4
Heads number in use..................... : 4
Switched off heads...................... : No
Heads map............................... : 0,1,2,3
thanks in advance
Data Recovery Pakistan
 Post subject: Re: Need Mod 11 : Fblite family
PostPosted: June 19th, 2017, 12:58
there are many available but Overlay F/W version..................... : 16.7DG whereas I need Overlay F/W version..................... : 16.7CG exactly.
PostPosted: June 21st, 2017, 15:13
desperately need this, anybody ??
Model: WD10JPVX-22JC3T0
ROM Modules:
PostPosted: June 21st, 2017, 15:37
I don't understand why these questions come up so frequently. AISI, the simple solution would be as follows.
    Obtain a matching ROM/loader combination, of any firmware version, for the patient drive.
    Patch the patient's adaptives into the donor ROM.
    Start patient drive with donor's ROM and loader.
    Retrieve native loader from SA.
    Restore patient ROM.
Of course I'm assuming that the native loader is not damaged.
PostPosted: June 21st, 2017, 17:18
your assumption is not correct, the native mod 11 is damage, infact drive has media scratch managed to extract the FW except mod 11, which is now required to do a smart hot swap.
thanks for the reply.
PostPosted: June 25th, 2017, 15:53
anyone ?
thanks
PostPosted: June 25th, 2017, 17:05
AIUI, there are 4 copies of this module. :?
PostPosted: June 26th, 2017, 4:15
For FBLite, the overlay version is always 1 larger than the ROM version !!!
ROM and Overlay for FBLite are always available in two versions for SA SPT 1437, and for SA SPT 1480
Version with G at the end is for SA SPT 1437
Version with H at the end is for SA SPT 1480
>SA SPT.................................. : 1437
>ROM:
>ROM reading............................. : Ok
>ROM Data size........................... : 256 Kb
>ROM generation.......................... : 16.7DG
>Link table version...................... : N0.41.
>Consolidated ROM version................ : 0016007C
>SA SPT.................................. : 1480
>ROM Modules:
>ROM version............................. : 16.7CH
>Overlay F/W version..................... : 16.7DH
If Overlay is not loaded into memory then the Overlay version will be equal to the ROM version as here
ROM Modules:
Mikippp
File comment: 0016007C SA SPT 1437
11.zip [496.2 KiB]
Downloaded 168 times
File comment: 0016007C SA SPT 1480
11.zip [496.15 KiB]
Downloaded 171 times
PostPosted: June 27th, 2017, 12:35
thanks alot. Mikippp
