 Post subject: WD3200LPWX LDR UPDATE
PostPosted: July 27th, 2017, 4:44
I need ldr for WD3200LPWX
ROM Modules:
ROM version............................. : 06.16J
ROM F/W version......................... : 00060016
Overlay F/W version..................... : 06.16J
Servo F/W version....................... : NB.11
 Post subject: Re: WD3200LPWX LDR UPDATE
PostPosted: July 27th, 2017, 10:25
WD3200LPVX (Hubble LT)
>ROM:
>ROM reading............................. : Ok
>ROM Data size........................... : 256 Kb
>ROM generation.......................... : 06.17J
>Link table version...................... : NB.11.
>Consolidated ROM version................ : 00060016
Mikippp
11.zip [469.2 KiB]
Downloaded 120 times
PostPosted: July 28th, 2017, 0:36
Thanks for your help:)
PostPosted: July 28th, 2017, 2:54
I upload ldr but I cannot solve my problem
Techno mode key
Techno mode key......................... : Ok
RAM:
HDD Info reading........................ : Ok
Heads number............................ : 2
Cyl Count............................... : 256
Zone allocation table................... : HDDs RAM reading error Device Error Detected: "SCT INVALID FUNCTION CODE"
ROM:
Read ROM................................ : Ok
Flash ROM dir reading................... : Ok
Flash ROM dir reading (Ext)............. : Ok (Active)
Modules directory address............... : 104 056
SA regions address...................... : by default
Module 02 access........................ : Granted
SA Translator loading................... : Ok
ROM Modules:
Overlay F/W version..................... : 06.17J
Heads number in use..................... : 2
Switched off heads...................... : No
Heads map............................... : 0,1
Service area:
Permanent overlay....................... : Not loaded
SA dir reading (ID)..................... : SERVO ERROR CODE BASE SvirActSpeed
SA SPT Detect........................... : FAIL
SA dir reading (ABA/CHS)................ : Module reading error: ABA 471 928(1) reading error Physical read error C/H/S: -48/1/57 Device Error Detected: "SERVO ERROR CODE BASE SvirActSpeed"
SA Access............................... : NONE
Configuration reading................... : Module 02 not found
