 Post subject: please LDR for WD10EADS-11P8B2 1.0TB
PostPosted: August 16th, 2017, 4:12
I need LDR .
ROM Modules:
ROM version............................. : 15.1VD
ROM F/W version......................... : 0015001V
Overlay F/W version..................... : 15.1VD
Servo F/W version....................... : 04.0P
Also when I run utility I got error given below can you help me how can I solve this problem
Techno mode key
Techno mode key......................... : Ok
RAM:
HDD Info reading........................ : Ok
Heads number............................ : 4
Cyl Count............................... : 192
Zone allocation table................... : HDDs RAM reading error Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
ROM:
Read ROM................................ : Ok
ROM Data size........................... : 256 Kb
Flash ROM dir reading................... : Ok
Flash ROM dir reading (Ext)............. : Ok (Active)
Modules directory address............... : 282 658
SA regions address...................... : by default
Module 02 access........................ : Granted
SA Translator loading................... : Ok
ROM Modules:
Heads number............................ : 6
Heads number in use..................... : 4
Switched off heads...................... : Yes
Heads map............................... : 2,3,5,7
Service area:
Permanent overlay....................... : Not loaded
SA dir reading (ID)..................... : SERVO ERROR CODE BASE SvirActPdFail
SA SPT Detect........................... : FAIL
SA dir reading (ABA/CHS)................ : Module reading error: ABA 282 658(1) reading error Physical read error C/H/S: 373/0/159 Device Error Detected: "VSC ERR KEY SECTOR MUST PRECEED DATA XFER REQUEST"
SA Access............................... : NONE
Configuration reading................... : Module ID 02 reading error Data request error Device Error Detected: "Unknown error code: 3746"
 Post subject: Re: please LDR for WD10EADS-11P8B2 1.0TB
PostPosted: August 16th, 2017, 15:13
what is the behaviour of drive ?
is it clicking ?
or spin down ?
tesukalar abi
Data Recovery Pakistan
PostPosted: August 17th, 2017, 0:31
There is unusual sound first spin up than spindown I thing there is a problem with heads and I want to try head map editing Do you have another idea .Also I think head cause bad sector on surface acording to sound.should I try change head map or fisrt open it in clean room but I dont have donor drive
PostPosted: August 17th, 2017, 1:51
HI,
here it is ,,,
http://files.hddguru.com/download/PC-30 ... 251248.zip[url][/url]
http://www.lifeguarddatarecovery.com
PostPosted: August 17th, 2017, 6:16
Thanks a lot:)
