 Post subject: WD drive isn't responding
PostPosted: August 31st, 2017, 5:11
Hello guys! :D
I have WD drive which comes ready after power on but hangs when I'm trying start the Utility.
Can somedody help me?
 Post subject: Re: WD drive isn't responding
PostPosted: August 31st, 2017, 11:38
what tools you are using ? can take a look remotely if interested
good luck
Data Recovery Pakistan
PostPosted: September 3rd, 2017, 1:57
he is using Pc3000 i think as post is in Pc3000 Category ...
http://www.lifeguarddatarecovery.com
PostPosted: September 3rd, 2017, 2:00
hi,
could you give more details about drive & Behavior when you power on .
PostPosted: September 4th, 2017, 8:42
Lylor wrote:
Hello guys! :D
sounds like common issue relating to device relocation parameters - clear parameters inside module #02 and empty #32 - you may need to force device into a ready state without loading current SA to RAM otherwise you will face BSY error constantly
PostPosted: November 22nd, 2017, 13:38
hddguy wrote:
Lylor wrote:
Hello guys! :D
Already forgot about my question here. Yes, it was like you said. There were problemas with clearing parameters but I managed! thank you
