 Post subject: WD10JMVW 2.5 usb - connect sata adapter
PostPosted: September 12th, 2017, 10:16
How to connect sata adapter to pcb for this drive?
help please
 Post subject: Re: WD10JMVW 2.5 usb - connect sata adapter
PostPosted: September 12th, 2017, 11:06
You will probably have a better chance of getting help if you post quality pictures of both sides of your PCB. That said, it might just be easier to use a SATA PCB. Typically 771960, 771939, 771959 for that drive (assuming it has a 771961 PCB).
Blizzard Data Recovery
PostPosted: September 12th, 2017, 13:14
I have only one side picture with me now.You are right its board number is 771961
PostPosted: September 12th, 2017, 13:17
There is no adapter per se. The conversion from SATA to USB is all built into the drive. There are two resistors that you can generally remove and solder into the SATA lanes if you must do it that way. However, it's generally easier to just transfer the ROM or ROM code to a matched SATA board. I've been keeping an updated list of compatible SATA boards on this thread: https://www.data-medics.com/forum/wd-pa ... e-t13.html
However, you'll likely find that by bypassing the USB bridge the data will be encrypted. So you'll need to have a method for handling the encryption afterward.
Hard Drive & RAID Data Recovery Services
https://www.data-medics.com/raid-data-recovery/
PostPosted: September 12th, 2017, 13:25
Also I dont have compatible pcb.
So I need coonect sata adapter
PostPosted: September 18th, 2017, 3:20
:lol:
PostPosted: September 18th, 2017, 3:30
And why don't you buy one?
It's cheap...
And with PC3K (which I assume you have) it's a job for a few minutes, instead of some time soldering...
http://www.facebook.com/PCLAB.Assistencia.Tecnica
ACELab partner
PostPosted: September 18th, 2017, 13:06
Here's the connection points: https://www.data-medics.com/forum/board ... t1828.html
