 Post subject: Flash boot code checksum failure! on ST2000DM001
PostPosted: June 17th, 2018, 13:05
I need some help
I have this drive and it was clicking . we find the right donor and replaced the head
now after the head is replaced on pc3000 terminal I am getting the following error
drive show busy and can not read
Here is the drive information
look like rom is corrupt
Model no: ST2000DM001
PART NO PYN164-500
FW CC4B
wwn 5000c500497d2b25
date 12407
site wu
Terminal log shows as follows
SEA4 Boot ROM 2.0 (05/03/2010)
Copyright Seagate 2010
SEA4 Boot ROM 1.0 (05/03/2010)
 Post subject: Re: Flash boot code checksum failure! on ST2000DM001
PostPosted: June 17th, 2018, 14:37
Have you removed or switched the ROM at any point?
PostPosted: June 17th, 2018, 16:11
If you upload your ROM dump, I could check it for you.
PostPosted: June 30th, 2018, 16:20
Usually that happens when rom chip pins have bad soldering joints to pads (in this case motor will not even spin).
Check rom pins under microscope, if you see that soldering is bad then solder it again properly by using Amtech or MG flux paste.
Or it might be that rom got damaged.
PostPosted: June 30th, 2018, 18:03
Agree ... Either the ROM got damaged or the PCB is not working properly ... etc ...
PostPosted: June 30th, 2018, 18:04
Maybe you can still READ some parts of the ROM.... Hopefully getting the adaptives to "patch" another working ROM ?
