 Post subject: Damaged ROM WD10TMVW-11ZSMS0
PostPosted: September 4th, 2018, 7:32
Can anyone please help me how to find compatible ROM to this drive? PCB of patient is bad and I want to avoid soldering. I tried about 10 different ROMs of size 512 Kb, but nothing works. The ROM has maybe size of 256 Kb.
HDD ID:
WD10TMVW-11ZSMS0
DATE 21 OCT 2010
DCM EBMTJBBB
SN WXP1E80Z9966
If you have any advice how to solve this case, please let me know.
Thanks.
 Post subject: Re: Damaged ROM WD10TMVW-11ZSMS0
PostPosted: September 4th, 2018, 14:56
Have seen a lot of bad Helios drives, but not many pcb´s - whats wrong ?
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: September 13th, 2018, 17:29
If you have PC3000, have you tried to read ROM by COM-port?
Or the PCB is 100% dead?
ACELab partner
PostPosted: September 15th, 2018, 9:14
Helios drive use 2 different PCBs i think, whats the number on PCB ?
Data Recovery Pakistan
PostPosted: September 29th, 2018, 9:11
Thanks.
Why? resoldering ROM to e good electronic board is the chipest and best solution.
Backup is Your best friend. Still learning English. Sorry for language bugs. My websites: Centrum Odzyskiwania Danych
PostPosted: September 29th, 2018, 20:48
Adaptives are stored on ROM as well as ROM code so you do need original ROM and you can't just use ROM downloaded from the net unless you adapt some of the ROM modules by using some tricks ...
If you do want to avoid soldering use this method :
http://www.hddoracle.com/viewtopic.php?f=110&t=1738
External programmer + SOIC 8 clip ...
Assuming of course your drive have external ROM chip ...
