HDD GURU FORUMS
http://forum.hddguru.com/
ST1000LM035 another problem with rosedwood family
http://forum.hddguru.com/viewtopic.php?f=11&t=37497
Page 1 of 2
Author:  hamidbid [ October 6th, 2018, 13:16 ]
Post subject:  ST1000LM035 another problem with rosedwood family
Hi guys,
I have a ST1000LM035 after patch don't have to sa and terminal
In log window
HDD Redynes timeout (10000)
Family ID by HDD ID: A5
Selected family......................... : A5, Rosewood_A5
Model by ID............................. : ST1000LM035-1RK172
Loading default settings!
Use the options dialog to review and save utility settings.
Then press OK!
Family default settings loading!
Tech Key...
Error starting command "En Tech" (Drive is not ready)
Terminal : reply timeout error
I think pending sector
and what is about "MS Read Fails" ?
and why give message "Update Mask" after patch ?
Thanks for any new idea :)
File comment: Terminal log window
6794.txt [265.03 KiB]
Downloaded 539 times
Author:  hamidbid [ October 6th, 2018, 15:46 ]
Post subject:  Re: ST1000LM035 another problem with rosedwood family
Hi again
short terminal log
Boot 0x80M
Tech Unlock Handshake: 0x0791FB18
Reply:
Rst 0x80MSrv DETCR init 0x0000
(P) SATA Reset
RAW OFF
PASS
(DOS Table) Worst Count: 00000D40 At SU: 0000531A NT: 00000000 OT: 0000000E
(POR) Recover Secondary MCMT Opened Recovered
MS Read Fails: 0EEE17B0,000052E8
Update Mask - 000000000EEE17B0 - 00000001 - 00
Update Mask - 000000000EEE17B1 - 00000001 - 00
Update Mask - 000000000EEE17B2 - 00000001 - 00
Update Mask - 000000000EEE17B3 - 00000001 - 00
Update Mask - 000000000EEE17B4 - 00000001 - 00
Update Mask - 000000000EEE17B5 - 00000001 - 00
Update Mask - 000000000EEE17B6 - 00000001 - 00
Update Mask - 000000000EEE17B7 - 00000001 - 00
Update Mask - 000000000EEE17B8 - 00000001 - 00
Update Mask - 000000000EEE17B9 - 00000001 - 00
Update Mask - 000000000EEE17BA - 00000001 - 00
Update Mask - 000000000EEE17BB - 00000001 - 00
Update Mask - 000000000EEE17BC - 00000001 - 00
Update Mask - 000000000EEE17BD - 00000001 - 00
Update Mask - 000000000EEE17BE - 00000001 - 00
Update Mask - 000000000EEE17BF - 00000001 - 00
Update Mask - 000000000EEE17C0 - 00000001 - 00
Update Mask - 000000000EEE17C1 - 00000001 - 00
Update Mask - 000000000EEE17C2 - 00000001 - 00
Update Mask - 000000000EEE17C3 - 00000001 - 00
Update Mask - 000000000EEE17C4 - 00000001 - 00
Update Mask - 000000000EEE17C5 - 00000001 - 00
Update Mask - 000000000EEE17C6 - 00000001 - 00
Update Mask - 000000000EEE17C7 - 00000001 - 00
Update Mask - 000000000EEE17C8 - 00000001 - 00
Update Mask - 000000000EEE17C9 - 00000001 - 00
Update Mask - 000000000EEE5EB1 - 00000001 - 00
Update Mask - 000000000EEE5EB2 - 00000001 - 00
Update Mask - 000000000EEE5EB3 - 00000001 - 00
Update Mask - 000000000EEE5EB4 - 00000001 - 00
Update Mask - 000000000EEE5EB5 - 00000001 - 00
Update Mask - 000000000EEE5EB6 - 00000001 - 00
Update Mask - 000000000EEE5EB7 - 00000001 - 00
Update Mask - 000000000EEE5EB8 - 00000001 - 00
Update Mask - 000000000EEE5EB9 - 00000001 - 00
Update Mask - 000000000EEE5EBA - 00000001 - 00
Update Mask - 000000000EEE5EBB - 00000001 - 00
Update Mask - 000000000EEE5EBC - 00000001 - 00
Update Mask - 000000000EEE5EBD - 00000001 - 00
Update Mask - 000000000EEE5EBE - 00000001 - 00
Update Mask - 000000000EEE5EBF - 00000001 - 00
(MC POR Duration): 0000014E39
Intel 6G->3G
Send Status: COMRESET seen
CSpd= 3Gbps
(DOS) SU:0000E84B Ct:00000C6C Adjusted BRO: 0001DDC17B - 0001DDCD52
Starting LBA of RW Request=0001DDC17B Length=00000BD8
ProcessRWError -Read- at LBA 0001DDC17C Sense Code=43110081
Common path start quit now ProcessRC: 00000000,00000000ReadContinuous: 01DDC17C,0000017AUnrecovSectorCount:00FE,0179NumUDEs: 000000FE,00000179Passed: 00000080,0000012F,00000154Out:
SP Regen FAIL
SPRegen [0000|43110081] @LBA=0x01DDC17C
Setup currentretry count
Hd 0 Err Blk 1DDC17C BER pre -1.872396
Out:
Update Mask - 000000000EEE0BE0 - 00000008 - 00
Harden - 01DDC17C
InitiateMarkPendingReallocateRequest for disc_lba: 0001DDC17C CHS: 0000E84B.00.0001
Assert 741D - LBA 01DDC17C!
ProcessRWError -Read- at LBA 0001DDC182 Sense Code=43110081
Common path start quit now ProcessRC: 00000001,00000000ReadContinuous: 01DDC182,000002EFTotalEntries:0174 XfrLen:02EFUnrecovSectorCount:00FB,0173NumUDEs: 000000FB,00000173Failed: 40000087Out:
SP Regen FAIL
SPRegen [0000|43110081] @LBA=0x01DDC182
Hd 0 Err Blk 1DDC182 BER pre -1.872482
Out:
Update Mask - 000000000EEE0C10 - 00000008 - 00
Harden - 01DDC182
InitiateMarkPendingReallocateRequest for disc_lba: 0001DDC182 CHS: 0000E84B.00.0007
Assert 741D - LBA 01DDC182!
ProcessRWError -Read- at LBA 0001DDC183 Sense Code=43110081
Thanks for new idea?
Author:  hamidbid [ October 8th, 2018, 4:02 ]
hi again
More description
After unlock in utility start (in PC3000 UDMA) near one minute later hard disk ready
next hdd Read HDD ID worked then push on utility start
in log window
Tech Key...
don't have access terminal and also sa and hdd came busy
This problem has solution till now
appreciate for any answer
Author:  MindMergepk [ October 8th, 2018, 5:54 ]
there is a solution :idea:
let me know if you need remote help.
Author:  Orizarrb [ October 9th, 2018, 3:17 ]
I had the similar case with same errors and asked ACE support to help me via teamviewer.
Not sure what they did, I remember they unlocked the drive first, it was too fast, but I read all data I need after that.
Author:  hamidbid [ October 14th, 2018, 7:58 ]
Thanks ,I sent pm
Author:  hamidbid [ October 14th, 2018, 8:10 ]
thanks for answer,
Unfortunately , I don't have any support from two months ago :)
Author:  hamidbid [ October 19th, 2018, 13:03 ]
with Thanks Wasim,
I can get new idea , and tray many time and in last , I found solution :D
Author:  mrdoktro [ January 8th, 2019, 15:34 ]
Hi! Hamidbid did you find a solution?
Author:  HDDscholar [ January 9th, 2019, 23:54 ]
hamidbid, mrdoktro
This is not problem of this drive, from message you share, after you unlock the drive, PC3000 did not succeed to exchange command, maybe the bug of PC3000 or poor disk condition. ACE support just re-do the Handshake on Teamview after unlock, and you can get data, that would be the story, no big things.
Reminds! big things happen when you regenerate translator after above process, the link below list detail discussion about Rosewood drive translator issue,
for your reference https://forum.hddguru.com/viewtopic.php ... 10&start=0
Someone who attended Ace Labs conference in Las Vegas June 2018 said ACE had found Media Cache maybe the cause of this issue, but until now they have not release any solution. So be careful with translator of ST Rosewood for new engineers. Follow the tips from post do help you in future.
Author:  MindMergepk [ January 10th, 2019, 6:11 ]
can you share the terminal log ?
Author:  manhcuongvn [ January 12th, 2019, 4:29 ]
step 1 unlock techmode in rom
step 2 goto teminal backup 28, 93..etc
step 3 translator by command.
Step 4 change 93 module in ATA mode. and restat power
done. 100% success my case
Author:  mrdoktro [ January 12th, 2019, 15:27 ]
Hi MindMergepk. I had no problem with unlocking the disk. Only the first time I was recovering data from the rosewood disk. Some wrote that you can not touch the translator and SMART, and others that you have no choice but to regenerate the transistor, because the problem is in the system file 93, and without regeneration, you will not get access to this file. And so I did, first on an identical test disk and then on the target one. 99.5% of data recovered, 0.5% bad block.
Author:  Lylor [ January 14th, 2019, 12:03 ]
This problem caused by damage to Media Cache. You should repair it, because it has critical information for data recovery. The optimal way is to read MC system file with error ignoring re-read bad sectors (PC3000 allows to do that). Finally you combine good part of it with bad part together and write fixed in the drive. After repower you should get full sector access.
Author:  HDDscholar [ January 14th, 2019, 23:08 ]
I followed your steps but failed. ended with LED, is there any misoperation? later I will update a video to show you.
@Lylor would u please specific more detail here about Media Cache, how to handle the situation.
Author:  HDDscholar [ January 15th, 2019, 3:42 ]
Pls see my operation, any suggestions? thanks in advance.
https://youtu.be/QgpAyz3iXd4
Author:  northwind [ January 15th, 2019, 5:03 ]
NO.
This will cause lost MC data.
Author:  MindMergepk [ January 15th, 2019, 8:14 ]
well, I am glad you have recovered it.
You can count me with those guys who says never touch translator.
Author:  Spildit [ January 15th, 2019, 19:35 ]
northwind wrote:
NO.
AGREE !!!!
Author:  Alikhan [ January 15th, 2019, 23:16 ]
Media Cache has been repeatedly emphasized in topics about rosewood, however some technicians I know from DFL told me to ignore MC when dealing with LM, they even published a feature to fix partial sector access in their latest update. And allegedly there are numerous cases proven to be solved by their new feature. I just wonder if algorithm against ECC enables us to gain access to user data, why insist on working with MC? Even in ACE's free support blog, there are articles about recalculating translator after backup of vital sys files
Page 1 of 2 All times are UTC - 5 hours [ DST ]
http://www.phpbb.com/
