 Post subject: Hitachi sector access interruption
PostPosted: December 26th, 2018, 15:11
Hi
I don't own pc3000 but I need to know,in hitachi arm when you have no access to user data and you need to load PSHT and RDMT so is other imaging setting are available to work with it ?
Can you choose pio or udma mode and change timeout settings to work with the virtual translator ?
 Post subject: Re: Hitachi sector access interruption
PostPosted: December 31st, 2018, 15:10
Never mined,I thought it will be advantage of pc3000 but eventually I found how to do it in MRT it's a different way than you do in toshiba.
PostPosted: January 4th, 2019, 3:05
virtual translator only run if you can read PSHT and RDMT. :? :?
DATA RECOVERY SERVICE VIETNAM
Cứu dữ liệu ổ cứng| Cứu dữ liệu máy chủ |Phục hồi dữ liệu
