 Post subject: ST4000DM004 - can't change head map / set max head
PostPosted: March 20th, 2019, 14:13
Hi Gurus.
This drive spins up, clicking two times and spins down with ready state + ABR but IDs fine.
Terminal output is following:
Boot 0x0100MAF00550001
SpinUp
FAIL Servo Op=0100 Resp=0003
0100 9000 0000 0001 0000 9015 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
ResponseFrame 1700 0000 0000 4700 0000 0000 0000 0000 0CA6 0000 CE00 0000 CE00 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 FFFF 0000 0004 8931 FFA6 007F 0019 0006 0005 Loop=007F
ResponseFrame 0000 0000 0000 0000 0000 0000 0000 0000 18F4 0000 CE00 0000 CE00 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 FFFF 0000 0004 8931 FFA5 007F 0031 0006 0000 Loop=007F
Probably it's bad heads, so i read ROM via "utility extensions-> work with flash rom" and tried to do log/phys head map editing/set max head to 0 in ROM but always get following error "Can Not Set up Head Map Info".
Can anybody help ?
Regards, Boerge
 Post subject: Re: ST4000DM004 - can't change head map / set max head
PostPosted: March 20th, 2019, 15:02
As far as I know, this model is not supported for head map yet.
PostPosted: March 28th, 2019, 19:40
this one is V11, not natively supported by pc3k, but i have solution to work with it.
No bitcoin donations :)
