HDD id has not been read
http://forum.hddguru.com/viewtopic.php?f=11&t=38292
Author:  rohitdharan [ April 9th, 2019, 6:16 ]
Post subject:  HDD id has not been read
Hello experts.
greeting of the day.
I am facing the issue while using pc3000 "hdd id has not been read, capacity is .49mb(1000)"
and the status is showing DWF
please help[ me to solve this issue so that i can recover my data.
Author:  data-medics [ April 9th, 2019, 11:43 ]
Post subject:  Re: HDD id has not been read
You need to fix whatever is wrong with the hard drive. There's no push-button solution here. I'd start by replacing the PCB and see if that helps. Could be heads, media damage, or any number of other causes. We'd need a lot more information to even attempt to help you.
Author:  Spildit [ April 9th, 2019, 13:51 ]
Full model of your Seagate HDD ?
Most likely it will be a F3 Arch drive and NOT a ST-10 / U5 so you might be using the wrong PC-3000 utility ...
Author:  rohitdharan [ April 10th, 2019, 0:24 ]
model: Seagate
s/n: 9TX110YJ
ST3320310CS
Author:  Spildit [ April 10th, 2019, 13:47 ]
F3 Arch drive....
Baud rate of 9600 is for older ST-10 ... It will NOT display terminal log on F3 ARCH. You have wrong settings and you are using wrong utility ....
Author:  rohitdharan [ April 12th, 2019, 0:53 ]
Spildit wrote:
F3 Arch drive....
Then give me the solution for this..
Author:  fzabkar [ April 12th, 2019, 1:05 ]
rohitdharan wrote:
Spildit wrote:
F3 Arch drive....
Choose F3 Architecture (Garbo family?), baud rate = 38400bps
Author:  Spildit [ April 12th, 2019, 16:13 ]
rohitdharan wrote:
(...)Then give me the solution for this..
Send the drive to a REPUTABLE data recovery firm ?
At least get the drive LOG by using the correct baud rate ...
Does the drive spin at all ? Does the drive click and spin out ?
Can you read ROM in boot code mode ? If so does the serial match the drive label ?
Etc ... Etc ...
Author:  Spildit [ April 12th, 2019, 16:17 ]
Yeah ... should be a "Garbo" most likely with something like SC14 firmware .... Firmware number for F3 ARCH (format) is 4 consecutive characters so "Garbo" and F3 ARCH for sure ...
Author:  rohitdharan [ April 14th, 2019, 23:54 ]
Thank you ALL for your help and your time :)
Author:  Spildit [ April 15th, 2019, 13:55 ]
No problem ....
Let us know if you do manage to recover some data out of it !
Or at least get a proper terminal log ...
