fzabkar,
I have an Model=SAMSUNG HD501LJ, FwRev=CR100-10, SerialNo=S0MUJ1CP205465 .
I had no success to flash the latest firmware with Dell Update File
and now my other problem ist that the drive is far away from me and allready build into a Linux-System, wich i can access with ssh, so i need to find a way to flash the Firmware file under Linux!
But now my biggest question is now:
the file: "CR13B12M.DN4" is all i need ?? to put this with like hdparm on to the Harddrive or will i do a big mistake and the Drive would be after putting the "CR13B12M.DN4" File on a bricked device ?
I can't see any similarity between Samsung's .DN4 firmware images and the PC-3000_UDMA .pcr firmware file.
What does this mean... the file(s) CR13B12M.DN4 and CP13B14M.DN4 are not correct?
BTW, the DN4 images are byte-swapped.
and also what do you exactly mean with this comment, sorry i dont understand.
Cause you also said its byte swapped ...
Thank you so much for your time and i hope, fzabkar can give me Answer to my Question(s).
