 Post subject: NEEDED: WD Pinclite resources
PostPosted: September 26th, 2019, 11:50
Can anybody provide me a loader please? Thanks in advance!
RAM:
HDD Info reading........................ : Ok
Heads number............................ : 2
Cyl Count............................... : 170
ROM:
Read ROM................................ : Ok
ROM Data size........................... : 192 Kb
Flash ROM dir reading................... : Ok
SA regions address...................... : by default
Module 02 access........................ : Granted
ROM Modules:
ROM version............................. : 05.FHE
ROM F/W version......................... : 000500FH
Overlay F/W version..................... : 05.FHE
Servo F/W version....................... : 04.0K
Heads configuration..................... : by map
Heads number in use..................... : 2
Switched off heads...................... : No
Heads map............................... : 0,1
 Post subject: Re: NEEDED: WD Pinclite resources
PostPosted: October 8th, 2019, 14:29
Nobody?
PostPosted: October 8th, 2019, 17:40
Model of the drive?
http://www.pclab.com.pt facebook.com/PCLAB.Assistencia.Tecnica
ACELab partner
PostPosted: October 15th, 2019, 8:21
WD3200AAKS-61L9A0
PostPosted: October 15th, 2019, 17:38
Sorry, nothing here...
ACELab partner
PostPosted: October 16th, 2019, 5:33
Thanks for having a look!
PostPosted: October 17th, 2019, 1:53
i checked it last week, no luck... :(
No bitcoin donations :)
PostPosted: October 17th, 2019, 3:07
Try this 000500FF
it should work with SPT 1311 if ur drive is somehow good
000500FF.rar [331.19 KiB]
Downloaded 137 times
PostPosted: December 5th, 2019, 21:21
Is it still need ?
File comment: 000500FH
500FH_11.zip [156.68 KiB]
Downloaded 97 times
