 Post subject: Need LDR - WD10SPZX 0012000T
PostPosted: May 19th, 2020, 21:18
Need LDR for 0012000T
Anyone that have could be so kind to share?
ROM version............................. : 02.0GP
ROM F/W version......................... : 0012000T
Overlay F/W version..................... : 02.0GP
Servo F/W version....................... : 01.3C
p.s.
The one in http://files.hddguru.com/download/PC-3000-UDMA%20Support/WDC%20Marvell%20family%20utility/Palmer/ does have a different model and doesnt work
Thanks in advance!
 Post subject: Re: Need LDR - WD10SPZX 0012000T
PostPosted: May 20th, 2020, 3:31
:idea: Here you go
10 , 11 , 1B
Good luck
ldr.rar [728.09 KiB]
Downloaded 11 times
Tawfeek Mokhtar
http://alsafwapc.net
Alsafwa Data Recovery Egypt
PostPosted: May 20th, 2020, 20:59
Thank you!
With your LDR I made some progress
Mod 11 from the above message is version 00020029
I need mod 11 version 0002000H
Also need mod 04, ROM and ROM modules from this FW (where mod 11 have version 0002000H)
If anyone have and could share to help ...
Also, full sa backup (all mods + rom + rom mods) would be great :D
PostPosted: May 21st, 2020, 5:06
-BR- wrote:
Thank you!
that's weird .. i search in my D.B with 0012000T
Tawfeek Mokhtar
PostPosted: May 21st, 2020, 5:51
Tawfeek wrote:
-BR- wrote:
Thank you!
Don´t worry, you´ve searched correctly for what I asked the 1st time 8)
0012000T is the correct ROM F/W version
Note that module version and ROM F/W version are different things
What I pointed out in the 2nd request, was that I needed mod 11 with module version 0002000H, and your mod 11 version was 00020029
It is possible to have different module versions under the same ROM F/W version
In this case for ROM F/W version 0012000T, I found module 11 versions 00020029, 0002000H, 0002001B, and there might be others ...
On a final note for this request, I already found mod 11 version 0002000H and I´m currently recovering data from hdd 8)
Thank you for helping!
