 Post subject: Data cant be decrypted in DE Task
PostPosted: July 1st, 2020, 6:34
I have WD Hubble 500GB WDC WD5000LMVW-11VEDS3 drive. All essential modules are ok. But 33 plist on head0 is bad in zeros.
1. Can I reduce its size in dir editor?
2. Sectors are not accessible without using utility. I can decrypt and access sectors in utility by using "use utility" option. But in DE task I can only access sectors but its not getting decrypted. What could be the issue?
Best Regards,
Murtaza H.
FreekinGeeks Data Recovery
 Post subject: Re: Data cant be decrypted in DE Task
PostPosted: December 3rd, 2020, 17:57
You may need to check the decrypt button in task Parameters.
you may have to set up the task with the utility being active in the background and have it set up for imaging to a vhdx file or drive to drive etc.
