 Post subject: Unable to create head map
PostPosted: July 26th, 2020, 3:27
Hi everyone im working on Samsung 1tb u can serial no. And Model no. I have cut head2 as it was having scratches and head1 not ok and slist module is damage in head0 I changed head map in RAM drive detecting I COPIED FIRMWARE FROM HEAD0 but not able to create head map in DE can you suggest me what to do ?
Can I replace Slist module with do ornate drive module ?
 Post subject: Re: Unable to create head map
PostPosted: September 1st, 2020, 16:46
No you cant. Slist is very significant to be original.
Angel Data Recovery
PostPosted: September 2nd, 2020, 9:46
is it damaged in the used area? If not, you can still use it for head map building, however, you need to convince the drive to load it somehow.
No bitcoin donations :)
