 Post subject: WD10JPCX-24UE4T0 / ROM FW 0016007C
PostPosted: November 16th, 2020, 6:49
Hello everybody;
I have uploaded compatible LDR&DIR and saved original SA modules of this drive. Now when I try to upload DIR and LDR in to the RAM it is going to ready state in normal mode. But I can not read user data at all. I took ABR error on every sector. Then I have realised that translator can not be read by any head but composite reading. I made manuel head test and head 1 can write more successfully. Then I tried to write translator with head 1 but it gives "Module : 31............................. : Module 0031 writing error ABA 5041 writing error Device Error Detected: "DISK SERVO WRT FLT OFFTRACK ERROR"" Any suggestions for me?
Thank you.
 Post subject: Re: WD10JPCX-24UE4T0 / ROM FW 0016007C
PostPosted: November 16th, 2020, 9:55
But head 0 is dead?
If yes, you should do a head swap because even if you can solve the SA problem, you will get partial data and corrupted files.
ACELab partner
PostPosted: November 16th, 2020, 15:36
pclab wrote:
But head 0 is dead?
Yes but I want to get half of data at least firstly.
