HDD GURU FORUMS http://forum.hddguru.com/ |
TOSHIBA MQ COMPATIBILITY FOR HEAD SWAP EXPERIENCE http://forum.hddguru.com/viewtopic.php?f=11&t=40664 |
Page 1 of 1 |
Author: | smecca [ December 2nd, 2020, 6:03 ] |
Post subject: | TOSHIBA MQ COMPATIBILITY FOR HEAD SWAP EXPERIENCE |
Sorry guys, I was just wandering if someone of you has ever tested successfully, for TOSHIBA MQ DRIVES, head swap from a donor having the match with the only second part of rev before "/". Just an example: patient : xxx yyyy/ donor: xxj yyyy/ Of course with model and manifacturing country both perfectly matching. Thank you in advance for your answers. |
Author: | melvin [ December 2nd, 2020, 6:18 ] |
Post subject: | Re: TOSHIBA MQ COMPATIBILITY FOR HEAD SWAP EXPERIENCE |
It's hard to find a donor that doesn't work in MQ. |
Author: | smecca [ December 2nd, 2020, 7:43 ] |
melvin wrote: It's hard to find a donor that doesn't work in MQ. DONOR D.REV: AAE AA11/ PATIENT D.REV: AAE AA00/ It didn't work. And replacing donor heads back in donor drive it worked again perfectly. |
Author: | melvin [ December 2nd, 2020, 12:11 ] |
Guess you were "lucky". |
Author: | smecca [ December 6th, 2020, 10:39 ] |
Yeah! very lucky! Anyway, after testing 4 headsets, i finally got a perfectly matching donor and drive started like a charm. 100% data recovered, and an happy customer for my work. |
Page 1 of 1 | All times are UTC - 5 hours [ DST ] |
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group http://www.phpbb.com/ |
