HDD GURU FORUMS http://forum.hddguru.com/ |
Hitachi pcb changed http://forum.hddguru.com/viewtopic.php?f=11&t=42468 |
Page 1 of 1 |
Author: | jtb1982 [ June 1st, 2022, 9:16 ] |
Post subject: | Hitachi pcb changed |
I receive a hitachi hdd the model is HTS545050A7E362 and the pcb is changed, with the pc3k i read the rom serial number and is not the same serial number as the label, I don't have much experience with this brand, the client already went to 2 mac technical services and in the last place they changed the disk from the laptop, I even believe the technical service give my client a brick. And I don't believe the client can recover the original pcb. I want to know if it is possible to rebuild the rom from the firmware like in WD? or do some sort of hot swap? I I know the last method is not very possible. When I search in the blog all similar questions the answer is no, I only ask if there exist some exception. Thanks to all to read my post My best regards |
Author: | Amarbir[CDR-Labs] [ June 1st, 2022, 13:04 ] |
Post subject: | Re: Hitachi pcb changed |
jtb1982 wrote: I receive a hitachi hdd the model is HTS545050A7E362 and the pcb is changed, with the pc3k i read the rom serial number and is not the same serial number as the label, I don't have much experience with this brand, the client already went to 2 mac technical services and in the last place they changed the disk from the laptop, I even believe the technical service give my client a brick. And I don't believe the client can recover the original pcb. I want to know if it is possible to rebuild the rom from the firmware like in WD? or do some sort of hot swap? I I know the last method is not very possible. When I search in the blog all similar questions the answer is no, I only ask if there exist some exception. Thanks to all to read my post My best regards Hello , Please Share The ROM and Top Label of The HDD |
Author: | pepe [ June 2nd, 2022, 18:10 ] |
SN is byte swapped, take it into account. If it still doesn't match, you either have to have the client to get orig pcb or i can help with recovering the nvram and the data from the drive. pepe |
Page 1 of 1 | All times are UTC - 5 hours [ DST ] |
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group http://www.phpbb.com/ |
