 Post subject: SpyGlass2 2.5 Firmware corruption
PostPosted: August 2nd, 2022, 22:07
Hi Everyone :)
Please help me.
I got the following drive:
Model : WDC WD50NDZW-11MR8S1
Serial : WD-WX62D51EFKXD
Firmware : 02.01A02
Capacity : 5 TB (9 767 475 632)
I converted the USB only to SATA.
The drive give full recognize and full SA access but doesn't give any sector access.
The firmware is corrupted.
Since the drive is SpyGlass I am afraid to do any translator regeneration or anything else.
I found that 190 module is corrupted or can't be read normally.
Besides of that module all the other modules are ok.
| 0190 | 0 | Ad | 411 924 | 208 488 | No | | | | | Second level translator |
| 0190 | 1 | Ad | 411 924 | 208 488 | No | | | | | Second level translator
Any way to deal with the drive?
I only need to read the file list. That's all.
I attached the report from PC3000
What should I do next?
Best Regards :)
 Post subject: Re: SpyGlass2 2.5 Firmware corruption
PostPosted: August 3rd, 2022, 9:17
If 190 is bad, I think your best option is read in PBA and do a RAW recovery
ACELab partner
PostPosted: August 3rd, 2022, 10:05
Hi :)
How do I read with PBA?
I rarly used that option and don't remember..
PostPosted: August 3rd, 2022, 12:00
it all depends on how exactly 190 is bad. pls send me 183 and 190 for analysis.
PostPosted: August 4th, 2022, 11:06
Hi Pepe
I uploaded the files to this link
190.rpm amd 183.rpm
https://www.filemail.com/d/fgwlkspumahjsin
Best Regards,
PostPosted: August 4th, 2022, 15:15
Hello, it is in pretty bad shape, can you back up regions and tracks? Both copies.
then upload it but compressed, not like the prev one :)
PostPosted: August 5th, 2022, 0:18
When tring to read the tracks I get those error messages:
Physical read error C/H/S: -384/0/66 (1) Device Error Detected: "DM SECTOR OUT OF RANGE"
Physical read error C/H/S: -384/0/67 (1) Device Error Detected: "DM SECTOR OUT OF RANGE"
Physical read error C/H/S: -384/0/68 (1) Device Error Detected: "DM SECTOR OUT OF RANGE"
For the Regions how do I backup those?
Since I can only back up ROM, Modules, SA Tracks, RAM
Best Regards,
PostPosted: August 5th, 2022, 1:17
Best Regards,
Hi ,
Backup Copy 0 Side Platter 00 Side Only
PostPosted: August 5th, 2022, 5:25
Ctrl + Alt + 3
Open module 35
Open SA Defect list (edit in memory)
See which cylinders are turned off
Deselect disabled Tracks (Cylinders) when copying
Mikippp
PostPosted: August 10th, 2022, 9:04
Hi Pepe
Plaese check the The regions and the tracks here
https://www.filemail.com/d/undqdlqyaxgxpbe
Best Regards,
PostPosted: August 10th, 2022, 18:28
it seems to be a big mess, gonna take some time to find out if anything can be done...
Users browsing this forum: digisupport and 4 guests
cron
